Old 26-03-2018, 10:16 PM   #1
au350hp
Default Barra powered Charger
Saw this recently, thought one or two might appreciate it.
https://www.streetmachine.com.au/fea...ars_newsletter
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 09:31 AM   #2
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Default Re: Barra powered Charger
Smart conversion
Importantly it's still a six
And it's much more than just an engine swap;
I wanted EFI, air conditioning, power steering, reliability and modern handling
The plenum chamber and tunnel were shot too, so we replaced most of the floor and fitted the BA Falcon trans tunnel
We used the complete Ford front end, including the BA’s brakes, which kept the engineer happy
it drives amazingly well for a Valiant. I really appreciate the modernism of it
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 11:45 AM   #3
XByoot
Yes he’s done it well. I’d like to see how he set up the front end, the track of a BA is about 80mm wider than a Val....I checked! The turbo Barra is probably the best Australian produced engine in my books, and certainly the last. I’d love to fit one in my old Val one day, ultimate sleeper. My XB has to be done first, it’s consuming too much time, and money,and time, and money
My old Val
https://www.fordforums.com.au/showth...47#post6101547
I’ve got a few plans for her.
XByoot is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 12:05 PM   #4
Raptor
Raptor's Avatar
Originally Posted by XByoot View Post
Yes he’s done it well. I’d like to see how he set up the front end, the track of a BA is about 80mm wider than a Val....I checked! ...
An extra 40mm or so each side probably isn't an issue.
Seems like there's a bit of room there
Old 27-03-2018, 12:24 PM   #5
XByoot
True! Fills the guards better! There’s a place in NZ that puts a lot of modern platforms under old metal, I Love a dish in the rims and the wider track of modern cars can be restrictive. Not sure how you go legally widening the track, there is a limit but I’m sure there are ways!
Here’s another option
https://www.streetmachine.com.au/fea...-sedan-sleeper
The rod shop do a really nice K frame set up with coil over and rack and pinion. Not cheap but it’s probably a very solid option . Subframe connectors would be a must too, those old girls flex quite a bit.
Old 27-03-2018, 12:27 PM   #6
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Great job. I would have gone manual and really upped the power.
BA BF FPV starter button repairs. PM me.
Xtreme Ford Tuning
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
Old 27-03-2018, 12:33 PM   #7
XByoot
There’s two things I don’t like about the green charger, firstly is the front apron, but he mentioned it’s yet to be finished and it was a temporary fix...the second thing I don’t like about it is it isn’t mine! Upped the power?? Good call!
Old 27-03-2018, 01:54 PM   #8
Raptor
Raptor's Avatar
Not sure how you go legally widening the track, there is a limit but I’m sure there are ways!...
The regulations state that the track width of the donor vehicle applies
You use a Falcon front end - the Falcon track dimensions (plus modest allowances) are what applies. The only other requirement is that it has to be installed properly and has to fit - clearance for full suspension movement, steering etc.
Old 27-03-2018, 02:21 PM   #9
commodorenutt
commodorenutt's Avatar
The R&P steering from the BA would be a massive improvement too.
Good project. He needs to come up with a way to finish the console at the front, or maybe use an FG one that might integrate better.
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 03:48 PM   #10
XByoot
Interesting, do you have a reference? Certainly makes a swap viable and an excellent option but surely there are limitations.
Old 27-03-2018, 04:11 PM   #11
Raptor
Raptor's Avatar
Sure
VSB14 : NATIONAL CODE OF PRACTICE for LIGHT VEHICLE CONSTRUCTION and MODIFICATION
https://infrastructure.gov.au/roads/...ov_2015_v4.pdf
Page 44;
  • Track. Where non-original axle or suspension cross-member components are fitted, the offset of the wheel in relation to the axle or hub assembly used must not be increased by more than 12.5mm each side of the vehicle based on the specifications of the axle components used. If an axle assembly is shortened then the track width limit is taken as the axle manufacturers original track dimension, less the amount the assembly has been narrowed, plus 25mm
So you have the same allowance as a modified vehicle with original components (track +25mm which is the same as each wheel offset -12.5mm) but you measure from the donor vehicle specs.
Old 27-03-2018, 04:48 PM   #12
XByoot
Cheers I read that section. To me it mentions the wheel offset variation, not the actual track change of the suspension. It’s very interesting if it’s not restricted from donor to recipient. It’s obviously the case when looking at the green charger. Minimal dish rims up front to tuck under the guards...so basically don’t increase the wheel offset more than the specified amount in the regs and if it tucks under the guards it’s all good.very interesting and opens up a lot of possibilities. Thanks again
Old 28-03-2018, 07:57 AM   #13
OzJavelin
OzJavelin's Avatar
I've been in contact on FB with the guy who finally bought that N/A Barra-powered 1968 AMC Javelin .. would be great for it to be re-powered by a Turbo? ;)
BTW .. looks like it has an issue with the length of the engine too .. they can't install the orginal recessed grill as the engine comes forward too far ..
https://www.shannons.com.au/auctions...6CQB96I7Q84VE/
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2018, 01:48 PM   #14
au350hp
This beautiful '71' Mercury Comet is crying out for a Barra or a hot 289ci
https://www.carsforsale.com/1971-mer...-sale-C1060930
Old 01-04-2018, 08:52 AM   #15
aussie muscle
aussie muscle's Avatar
i don't like how the grille/headlights are not centered in the front grille opening. they are way too low.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
