#31 | |||
Mad Scientist!
"The clause for DPF is only for DPF's that don't suit the oil spec. This oil, suits your car spec, so it's ok to use" |
#32 | ||
Sounds like they're even more confused than we are.
The basic problem is that Ford specify the wrong oil. It should be a mid-SAPS oil meeting ACEA C2 or C3, but instead they specify a petrol / non-DPF diesel oil. Peugeot specify a C2 oil for the same engine in their cars. The oil manufacturers are never going to go against the Ford spec, but I'd love to know what they really think. I used to have regular DPF regens using the Ford recommended Castrol oil. I can't remember the last regen - maybe a year ago? Sent from my SM-G9208 using Tapatalk
#33 | ||
Just wondering how you know when it's doing a regeneration? As they don't have an idicator from factory. The guy that had my car previously fitted an led indicator that comes on when doing a regen cycle so I know every time mine does it.
#34 | |||
I really should get an OBD2 adapter. Sent from my SM-G9208 using Tapatalk
#35 | ||
I don't see how high SAPs oil would cause more frequent regenerations, it's the soot from the fuel which blocks the DPF and has to be burned off; not the ash, which is incombustible.
My understanding was that the ash from a high SAPs oil would build up pretty slowly and DPF would just need replacing sooner. I might give this a go next time: https://www.fuchs.com/au/en/special/...c-2-sae-5w-30/ It also has the PSA approval. |
#36 | ||
There are fuel additives that are designed to help clean the dpf. I've recently put one in and it seems to have reduced the frequency of the the rengeration cycles. It's suppose to put chemicals on the dpf that lowers the burning temp of the carbon or increases the burning temp when active. Can't remember which way round. The end result is,it's suppose to help clean the filter, which at the moment it seems to have done.
#37 | |||
All I know is that since changing to the Fuchs Titan ProFlex, the engine appears to have stopped doing DPF regens. It will be interesting to see what happens with the Penrite oil. Sent from my SM-G9208 using Tapatalk
#38 | |||
Which additive did you use? Sent from my SM-G9208 using Tapatalk
#39 | |||
#40 | |||
#41 | ||
Mad Scientist!
What's your technique on accurately getting the 5-6L oil out of the big 10L container?
#42 | |||
Challenge Accepted!
I work from the dipstick more than measured amounts, it's a tad more site specific. Works well for me without any mess but you do have to be on the ball when pouring. Had though about a drill powered pump but again more nonessential crap: https://www.bunnings.com.au/craftrig...-pump_p6320813
Undecided replacement... [SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD] |
#43 | |||
Mad Scientist!
I was thinking about getting this to help. http://www.kmart.com.au/product/wate...-litres/725801 Removing the spray tip. Fill till 5-6L, just pour in. |
#44 | ||
Keep an empty 5 l oil container, fill it from the drum, and that will get you about half way up the dipstick. Top up from there after running the engine.
#45 | ||
The watering can is a good idea.
Another good idea is a plastic storage box to put the watering can in otherwise you get insects and dust stuck on the oil. I have been using a 2 litre measuring jug 1 litre a time (challenge: count to 5) which has an open mouth unlike an oil container. I keep count with gravel and fill to half way up the hatched part of the stick. The upper mark means the maximum allowable and the lower means the minimum. The ideal is in the middle? So 5 litres goes in and top up is usually about 250ml. If the phone rings I look at the gravel when I get back. Last edited by rondeo; 02-02-2018 at 08:37 PM. |
#46 | ||
Challenge Accepted!
Well granted it is a safe working range and it's not like it's a hell of a lot more, but I don't know why you'd (not specifically you) not choose the top mark. With emissions standards as they are the oil is the new dumping ground, everything is being dumped in it, on top of lubrication and cooling duties.
#47 | ||
Mad Scientist!
I've also seen this, http://www.supercheapauto.com.au/Pro...05040/SPO82384
which i've also seen at Gasweld for $21. Might see if supercheap will match the price!! |
#48 | ||
$36 is a bit steep?
Looks good. Opening size would be OK at 10cm plus so no need to use funnel. I keep a funnel, 2l jug and rag in a plastic box. As for the dipstick On the max line it's nearer to overfill which theoretically means higher crankcase pressure and more weeping at crankcase seals, unless crankcase pressure is regulated? The difference between the min and max marks I think is 1 litre. |
#49 | |||
Challenge Accepted!
#50 | ||
The owner manual suggests
keeep the oil level between the limits. Surely the best approximation to that is the middle. I could be wrong about the crankcase pressure, if two pistons are going up and two are going down at the same time it shouldn''t make a difference. Anyway, can't do much harm I've done that for the last 40 years without problems. Or am I a tad obsessive? Now that I think of it isn't it just as obsessive to put it at the full mark? Last edited by rondeo; 03-02-2018 at 04:26 PM. |
#51 | ||
Crank case should be at atmospheric pressure or very close to it. The crank case is connected to the inlet before the turbo so any blow by can be recirculated back into the intake. If the motor is in good order there should be little to no oil or blow by. If the crank case is being pressurised then there's an issue.
#52 | |||
#53 | ||
Having the led indicator on the dash I know that mine regens about every 80-100km on the high way. Not having done an oil change on it yet, but knowing that the previous owner used valvaline synpower fe I don't see that would be out of the way. I would expect that the fuel would contribute far more to the regen frequency than th oil. At the end of the day if oil particular matter is clogging the dpf then that would indicate that the motor is burning the oil. As far as I know modern motors don't normally burn that much oil. If the motor is breathing heavily then this would increase the amount of oil being burnt, however I don't believe these motors breath that heavily. I also believe that the 2.0L level 5 immissions motors have an oil separator built into the crank case breather system which should remove the vast amount of oil going back into the intake system meaning virtually no oil is being burnt.
#54 | ||
I've just checked on the specification on the valvoline synpower fe, and while is designed specifically for these motor's and the ford standard it doesn't state that it's dpf safe. This seams to be a case of meeting the requirements for ford but not Peugeot. They do an Env c-2 as well as a mst c-3 which meet the Peugeot requirements and are dpf safe. So depending on cost I will also look at these as an alternative to the Penrite.
#55 | |||
Challenge Accepted!
#56 | |||
http://www.tridon.com.au/products/To.../428375/305040 Almost perfect! Can be capped at both the filler and the spout to keep bugs and dust out during storage. Re regens I think mine does at around 350km intervals, used mainly at 100km/h. Engine uses hardly any oil between changes, no need for top-ups. Using Nulon C3 changed at 15000km. Done about 170000km each on two cars Av fuel 6.2-6.4. Some fuels not so good- 6.7. No mechanical failures except turbo vacuum solenoid on both cars. $100 each. Last edited by rondeo; 06-02-2018 at 02:17 PM. |
#57 | |||
That’s a lot of regens. I’d encourage you to use a good C2 or C3 oil and see if it changes. I could not believe how much difference the Fuchs Pro Flex made - no regens and about 5% better fuel consumption. I suspect I will end up changing back to it. Someone else here has mentioned that the oil shouldn’t affect regen frequency. Sorry, but my experience for the last year is that it does.
#58 | |||
Mad Scientist!
Thank you to everyone for supplying lots of knowledge in this area. |
#59 | |||
Mad Scientist!
Have you put the C4 Penrite in your engine yet? Any noticeable changes? Nosier, economy, regens etc? |
#60 | |||
