Old 24-11-2017, 11:38 AM   #1
Sioso
irregular member
Sioso's Avatar
Default Tickford Bathurst '77 Mustang tribute
https://www.carsales.com.au/editoria...review-109929/
Tickford Bathurst '77 Special Ford Mustang 2017 Review
Tickford pays tribute to Moffat with limited-edition supercharged Mustang
Allan Moffat is an icon of Australian motor racing so it’s only right the anniversary of his legendary 1977 Bathurst victory should be celebrated. Even better when it’s done with a limited-edition which not only looks the part, but has the performance to match the livery
The joke about Allan Moffat among motor racing journalists used to be how he had a twin brother called ‘Arthur’. At race circuits Allan was a ferocious, focused and intimidating character (even before he got behind the wheel). But, in the right place, at the right time, away from racing, ‘Arthur’, this humorous, considerate, thoughtful and engaging bloke materialised.
Tickford’s Bathurst ’77 Special, or Moffat Mustang as we will call it from this point on, is a bit like that.
Created by the independent Ford tuner to celebrate the 40th anniversary of the incredible 1977 Bathurst 1-2 by Moffat’s Ford Dealer Team XC Falcon coupes (Moffat/Jackie Ickx first and Colin Bond/Alan Hamilton second), it has an incredible ferocity when poked, yet can also be quite relaxed in the right circumstances. Mind you, like ‘Arthur’, those circumstances don’t appear all that often.
What’s it all about?
You may not have noticed but Ford Australia isn’t interested in motor racing these days. The company pulled out of Supercars a couple of years ago, ending its relationship with Prodrive Racing Australia (PRA), or Ford Performance Racing (FPR), as it was previously known.
It also closed road vehicle tuner Ford Performance Vehicles, which for a long time was FPR’s sister company. So the owners of PRA set up their own tuning business, Tickford, using the same badge Ford employed pre-FPR back around the turn of the millennium to tune up Falcons and Fairlanes which went head-to-head with Holden Special Vehicles.
With Ford leaving the stage vacant, reborn Tickford took it upon itself to mark the anniversary of the greatest blue oval race result in Australian racing history, when Moffat led Bond over the line at Mount Panorama, their dominance of the race allowing a staged finish for the cameras.
With no Falcons around to use as a basis for its performance upgrades, Tickford turned to the Mustang GT, a fair enough substitute given Moffat is also famous for his exploits in the American pony car.
The outcome is a great example of how motorsport and hot road-cars intertwine.
At the core of the package is a Ford Performance Roush stage 2 supercharger kit – which Ford has ruled out selling itself because of Australian Design Rule drive-by noise regulations. But let’s be clear; the kit is ADR compliant. It boosts power of the 5.0-litre V8 from 306kW to 542kW and torque from 530Nm to 820Nm. Yowza!
Other new stuff includes a Tickford exhaust; a retuned and 25mm lowered suspension with German H&R coil-overs and dampers; extra rigidity via K-frame, strut tower and rear bracing; Wilwood brakes comprising six-pot calipers clamping on 381mm slotted rotors up-front and 355mm rotors and four-piston calipers at the rear; 20-inch Michelin Pilot Sport 4S tyres on delicious 10-spoke alloy wheels and various interior upgrades including a new leather trim and Tickford badging.
Oh, did we mention the exterior? Yep. It’s got the ’77 MFDT XC look right down to the #1 on the doors and bonnet. If you think the numbers are a bit too much, you can delete them.
How much will it cost?
The total cost of the conversion of a donor vehicle to Moffat Mustang spec is $64,500. That’s right, you can’t just rock into Ford dealer or a Tickford centre and buy one. You have to own and register the vehicle already. This is because Tickford is an aftermarket converter and not a car manufacturer.
Just 77 examples of the pack are on offer.
Because the kit is ADR compliant, the standard Ford three-year/100,000km warranty still applies. Tickford matches that for components it adds like trim materials and has a separate cover for powertrain.
Why should/shouldn’t I buy it?
If Ford, Ford motorsport, Moffat and Bathurst – especially 1977 - are pivotal in your life then this is the car for you. If you are a Holden guy then forget it.
If you are a petrol-head who loves immense power and response then, again, this car is for you. It has lock you-in-the-seat rictus-grin thrust. During our time with it, the Moffat Mustang clocked 4.7 and 4.8sec zero to 100km/h times effortlessly. Tickford reckons 4.2s are achievable as well as 400m runs in the 12s – which seems credible given our experience with this car.
But if you want to hear the engine at work at anything much above idling or on the smoothest roads, then substitute another exhaust for the Tickford offering. There’s simply too much tyre roar and wind noise for it to be heard.
Which makes for an interesting driving experience, relying less on the engine audio than normal for gearchange points. Not that we changed gear often. On a winding road, such is the speed and torque range it’s often set-and-forget in third gear. By the way, our test car was an automatic with paddle shifters, but 85 per cent of buyers are taking the package combined with a manual transmission.
For a purist experience, we’d go manual too. But if you’re thinking on terms of a city daily driver then the auto make sense.
And this is where ‘Arthur’ becomes relevant, because trundling down the freeway, or cruising round town, isn’t as intimidating as you might expect - except for being the centre of attention because of that race-car paint job. In ‘Arthur’ mode the Moffat Mustang does its best to co-operate and be civil.
Having said that, a plush modern-day ride as delivered by some sports cars with adaptive damper systems doesn’t feature here. If, however, you appreciate a traditional lowered ride height and stiffness then this one’s for you.
In fact, the ride impact is not as annoying as the impact traversing bumps has on throttle control out of corners. There’s not enough pedal resistance so it’s almost impossible to stop your foot bouncing up and down like you’ve got a nervous tic, which inadvertently produces a staccato acceleration effect.
Tickford is aware of the issue and actually tunes it out of its own 360kW power packs for naturally-aspirated Mustangs. But it was loath to fiddle with the throttle tune of the Ford Performance system. It should have.
Another tuning detail; our test car had an overly responsive brake pedal. It may be an isolated issue, but the Wilwoods are super-powerful and it would be nice to have a little more progression in pedal feel.
Smoother roads really emphasise just how good the Moffat Mustang can be. The Michelins provide huge grip, so it turns in and accelerates out of corners incredibly well. It’s just that on the road you’re tapping about 20 per cent of the car’s capability. On the track it will be a real weapon.
When is it available in Australia?
The kit is on-sale now.
Because it is based on the GT 5.0-litre V8 Mustang, you get the gear which comes standard with the production version.
Key equipment highlights include seven airbags, a reversing camera, dual zone climate control, the Sync3 infotainment system including satellite navigation, Apple CarPlay and Android Auto and puddle lamps which project the Mustang image.
By the way, you can get your Moffat Mustang as a convertible too, but you miss out on the Tickford decklid spoiler.
Who will it appeal to?
Rusted on Ford, Mustang, Moffat and Bathurst fans.
Where does it fit?
The Tickford Bathurst ’77 Special has plenty of rivals from other Mustang tuners with access to Roush supercharger kits like Melbourne tuning legend Rob Herrod.
But, with HSV soon out of the V8 Commodore business, trying to think up any other 500kW rival for this thing which doesn’t cost at least double the money is a challenge.
This car is a hard-core outlier, but if you are into that sort of thing it’s a tempting one.
So, what do we think?
We think yee-hah! The Moffat Mustang is a completely heart-over-head buy. A return on investment is questionable. Your rewards come in other ways. Like sheer thrust, rareness and its celebration of an important piece of Australian motorsport history.
Tickford Bathurst ’77 Special Ford Mustang pricing and specifications:
Price: $64,500 plus the cost of the donor Mustang
Engine: 5.0-litre supercharged petrol V8
Outputs: 542kW/820Nm
Transmission: Six-speed manual/optional six-speed automatic
Fuel: 13.7L/100km on-test (auto)
CO2: 318g/km on-test (auto)
Safety Rating: Two-star (ANCAP) – standard Mustang GT Coupe
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 11:54 AM   #2
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
Default Re: Tickford Bathurst '77 Mustang tribute
Wow, its supercharged. I didn't realise that from previous reports. Thought it was just a sticker pack.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 01:46 PM   #3
Vesper Martini
Vesper Martini's Avatar
Ford Australia rules out the Supercharger due to noise regs, but its fine if an aftermarket kit can do it?
sounds like a copout Ford Australia
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 02:37 PM   #4
Sioso
irregular member
Sioso's Avatar
If you read down further it actually says the exhaust is so quiet all you can hear is wind and tyre noise - so in order to be compliant Ford would have had to forgo the sound they wanted - obviously Tickford didn't care.
I could be wrong but that is how I read it.
Old 24-11-2017, 03:04 PM   #5
If I was in the position to get one, I certainly would.
BTW, it is good to see Jackie Ickx name. I will always remember him for this:
He made a point when he was pretty much the last one or near to last off the grid and won the race.
Old 24-11-2017, 03:14 PM   #6
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Yes that is how it works.
Ford need to sell it as ADR compliant, which includes drive by noise.
Aftermarket just need to be roadworthy, which is static noise test.
Same situation for HSV Vs. Walkinshaw kits.
Walkinshaw exhaust is noticeably louder than any HSV,.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 03:20 PM   #7
au350hp
Will these be an appreciating sought after model in 10 years time? Who cares. I have been a big fan since I first saw it a few months back. Awesome that a road car is available in what looks like a virtual race car. I would prefer one of these to the last XR8 hands down.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 04:15 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
Times are slow though. With good tyres it will run in the 10's no problem.
Old 24-11-2017, 05:04 PM   #9
PooDog
PooDog's Avatar
Sooo .....what has been done to the internals ...rods piston etc , to handle this power , what about the stock getrag has it been strengthened or has the tremec 6060 been fitted ?
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 06:23 PM   #10
CoupeKing
Going by what the new owner briefly says in this video the bottom-end is stock, not sure about any other internals - sounds great skip to 5:00 if you must:
It appears from a photo in that article that it's a 2.3L supercharger. A updated model has recently been released which is 2.65L - maybe this might be slapped on the GT 500?
Anyhow, Roush are lucky enough to co-engineer their gear with Ford Performance, so they get all the inside-info that would no doubt help with reliability, efficiency and warranty.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 06:25 PM   #11
GTP534
GTP534's Avatar
I stand to be corrected on this but I understand Ford had an external automotive engineering company look at this as they were considering offering it through dealers.
Ford have a lot of other factors beside drive-by noise to evaluate that the aftermarket doesn't have to worry about, such as durability, warranty, safety and certification.
The end result was it didn't satisfy Ford Australia's internal criteria.
Currently no V8 in the garage!
GTP534 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 09:00 PM   #12
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
That is a beautiful shot!
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 09:24 PM   #13
jmack
for 130k+ i think i would rather look at a slightly older gt500 supersnake,happy with our standard 5.0 gt at the moment but i know where i would be spending 130k if i had it
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 10:38 PM   #14
au350hp
I reckon it's a safe bet that the last thing an individual contemplating one of these would be looking at is the price. Fair chance they already have some 60's yankee iron in their garage. I don't think any negative comments that appear about this limited edition will be from those who own one lol.
Old 25-11-2017, 07:30 AM   #15
PooDog
PooDog's Avatar
you could have an xr8 ,a stock mustang + change for mods/ a new garage to fit it all in ?
524nm torque
Old 25-11-2017, 08:27 AM   #16
SensationFG8
Neither is equivalent to what is delivered here, why compare apples and oranges? They are different cars targeted at different people.
Previous Rides
Bionic BA MKII XR6T 245kW I6 Turbo, 6spd Manual
Grey (yuk what was I thinking) AH Astra CDX Coupe 93kW NA I4, 5spd Manual
Sensation FG XR8 290kW NA V8, 6spd Automatic
Current Rides
Octane GTF SC V8, 6spd Manual, Manta 3" X pipes and hotdogs
Starlight Lotus Evora S 258kW SC V6, 6spd Manual
SensationFG8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 09:24 AM   #17
anobserver
Oppressive patriarch
anobserver's Avatar
Totally agree. I'd buy one to admire, and to drive. That's it.
anobserver is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 09:27 AM   #18
futura
futura's Avatar
Yes its supercharged. Just look at the times acheived. 4.7 & 4.8 sec to 100.
GTF Smoke with Black stripes.
futura is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 09:30 AM   #19
futura
futura's Avatar
Great looking car. Perfect racing livery for a street car. Would rather brembo brakes.
Old 25-11-2017, 09:47 AM   #20
roddy1960
roddy1960's Avatar
Does look great , doubtless goes great with the supercharger . If I was ever lucky enough to have the dosh to do this sort of stuff I'd want to go with a 78 Cobra look though if possible.
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 10:30 AM   #21
chrisandsharon
chrisandsharon's Avatar
Mate at work has bought one - or more to the point is getting one built. He also got the VIP treatment at Bathurst this year. He’s a happy man
chrisandsharon is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 11:54 AM   #22
Pedro
Pedro's Avatar
With "Wilwood brakes comprising six-pot calipers clamping on 381mm slotted rotors up-front and 355mm rotors and four-piston calipers at the rear" in the stopping department, it seems to have that area covered. Or are you inferring that you would just like to see the Brembo moniker on the calipers?
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 01:41 PM   #23
HO 3
HO 3's Avatar
Tickford will probably do a retro Cobra Mustang next year..............
Cheers Mick
HO 3 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 02:02 PM   #24
GTLEGEND
Yes nice shot!! Can anyone work out what car is outside the building through the glass? Yellow with chrome bumper. It just caught my eye.
Old 25-11-2017, 03:00 PM   #25
BPXR6T
So a blower kit, wheels, brakes, suspension and stickers costs $65K these days. Is that an Australia tax thing or does a Rousch go for similar dollars in the states?
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 04:10 PM   #26
There are a few to choose from. Here is a list starting with the base RS levek:
http://www.roushperformance.com/vehi...g-2017-rs.html
Stage 1
http://www.roushperformance.com/vehi...17-stage1.html
Stage 2
http://www.roushperformance.com/vehi...17-stage2.html
Stage 3
http://www.roushperformance.com/vehi...17-stage3.html
P51 Mustang
http://www.roushperformance.com/vehi...-2017-p51.html
Old 25-11-2017, 04:14 PM   #27
Wretched
Render unto Caesar
Wretched's Avatar
Noice, though without the decals. Wheels are very sexy, remind of those on the RS6.
At least Ford now have a 100k+ car too, to match HSV
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 04:23 PM   #28
Mercury Bullet
Cheers Mick
I hope not.
This retro stuff does nothing for me.
As an original Cobra owner I looked at the bf replica as some kind of joke.
Classics should be left in their glory.
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 04:26 PM   #29
Mercury Bullet
Haha, touche.
Ford have a bit of catching up to do though, we're at 300k now.
XC Cobra #181.
Old 25-11-2017, 04:28 PM   #30
au350hp
Please explain
Re the decals. Why would you remove them?
Totally agree with Mercury re the B series Cobra.
