Travis - 1999 Ford AU S1
I bought a Clock from a Series 1 Futura for my Series 1 Forte, I was just wondering, do they have the wiring and the connector already in them as I can't seem to find it. If not, does anyone know how to put them in?
___________
I too would like to know, I have a clock but not sure on how to connect it.
Still not having much luck.
Lurker
Man I wish someone would answer this one. I wanna know too.
ok, for anyone till wondering on this, i have done it.
it's only a month old, lol anyway....i'm assuming you all know how to get the dash facia off? if not, you need to remove the head unit and the ash tray. there are 2 screws in behind where the ashtray sits, and one off to each side of where the head unit sits. undo all these and simply pull it away from the dash (it won't go far because the heater controls will stop it). remove the falcon badge from the top of the dash and place the clock in the opening. screw the clock to the mounting brackets on the back of the facia. the wiring is as follows, i didn't use an actual plug, just small crimping terminals with electrical tape over the ends so they don't short out onto each other. you could also use heatshrink. for power, i tapped into the radio loom, you will have to check the wires if you have a stock head unit, as mine is aftermarket i tapped into the bridging loom between the 2 plugs. as for the clock this is the diagram: i'm pretty sure the dimming input is that one, but just check it. turn the parkers on and see if it dims, if it's not that one, it will be the one below it. acc power has to be those 2 terminals, otherwise you won't get any display out of the clock. as for the wiring, all power wires are available from the stereo loom, dash dimming included. off: (image 177) just on acc: image178 with lights on: image179 missing (sorry for the really crap quality, you can just make out the difference. i also think there are pins for a light for the buttons, but i'm not sure which ones they are. and the series 2/3 haven't got them anyway, so...) anyway, that's my quick write up on installing a clock into an au1. i think mine was out of an xr6, not that that should make any difference... good luck guys, hope this helps Last edited by Uncle_Ken; 14-11-2017 at 10:21 PM. Reason: pb |
any chance we can update the photo i can only see photo bucket seems to be happening alot
#7 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
UK
