30-01-2017, 10:06 PM | #91 | |||
just something about the Ford being able to run without coolant makes it a no brainer for long distance country running Able to continue driving to the next town if there is a failure is a massive safety feature in a country with remote travelling like we have in Australia |
30-01-2017, 10:14 PM | #92 | |||
2013 FG II PETROLEUM XR6 (PURCHASED BRAND NEW!) 1999 AU I XR8 HOT CHILLI RED (PROJECT!) 1999 AU I XR8 HOT CHILLI RED (PROJECT) (YES I HAVE 2) 1991 EB S-XR8 WHITE (PROJECT) 2000 AU II XR8 200KW VENOM RED (GONE) 1995 EF XR8- COBALT BLUE (GONE) 1991 EB S XR8- PEARL BLACK (GONE) 1989 EA GL 5 SPEED (GONE)[/I] [/B][/FONT] |
30-01-2017, 10:37 PM | #93 | |||
Ford Falcon AU Series and Territory Fail Safe Overheat System The Falcon AU and Territory engine management system has a failsafe overheat system. How this works is: Instead of the usual ECT (Engine Coolant Temperature Sensor) which measures the engine coolant temperature, it has a CHT (Cylinder Head Temperature Sensor) which is mounted at the rear of the cylinder head and measures the actual engine temperature. This sensor operates on a very wide temperature band width. • When the engine temperature reaches 108°c, the engine sends a signal to operate the climatic control in a recycle state to help cool the engine down. • At 120°c the OBD (Onboard Diagnostic System) warning lamp and the overheat warning lamp in the cluster illuminate and a fault code is stored in the Engine Management System to later be retrieved using the diagnostic test equipment. • At 140 °c the Engine management system will command two injectors at a time to be switched off and reduces the engine power. This allows these two cylinders to be used as air pumps to help cool the engine. The hotter the engine and the more the throttle is pressed down at this the more injectors are switched off. At the same time the automatic transmission line pressure is increased. • Finally at 180°c the engine is switched off, preventing a meltdown of engine components. The engine is then allowed to restart and run for 2 minutes on all six cylinders, to be able to drive the vehicle out of a danger zone. The engine will only be able to restart once the engine temperature has dropped below 140°c. |
30-01-2017, 11:48 PM | #95 | ||
Where to next??
Woops 'my bad' thought the Powershift was the only option for diesel.
___________________________ I've been around the world a couple of times or maybe more....... |
31-01-2017, 06:02 PM | #96 | ||
01-02-2017, 08:43 PM | #97 | ||
Took the dedicated LPG 2013 VE Sports wagon to Woodside VIC on Sunday and back. From Doncaster to Traralgon via freeway, and then through the steep Strezlicki Ranges down to Woodside beach.
Driving normally at the 100 and 110 kmh limits, 4 adults plus beach gear, hot day. so air con the whole way too. A total of 513.6 kms, refuelled 47.44 litres the next day. That is 9.24 l/100km actual. Similar results with other tanks i've filled at different servos mirror these results, so no fluke. Amazing. |
05-02-2017, 08:40 PM | #98 | |||
For starters, you'll be hard-pressed to find anything more comfortable for long journeys (unless you go European.) Secondly, unlike most common cars, Falcons (especially the engines) are built for huge kms. (Mostly its a waste, most people don't need it, but if you do there's nothing better.) LPG on freeway driving is very cheap to run. Parts are plentiful and cheap, provided you stick to models that were still volume sellers. If you are going to go looking at Diesels, do your homework. All are expensive to fix, but some are extortionate and have limited life. My son has a Patrol with the old 4.2TD. Agricultural, but goes forever Last edited by Crazy Dazz; 05-02-2017 at 08:59 PM. |
