Old 23-01-2017, 03:02 PM   #1
NX74205
NX74205's Avatar
Default Buying a KE Laser - things to look out for
My brother's buying a KE Laser Ghia auto as a cheap daily. Is there anything in particular to look out for?
The body looks straight, doesn't appear to be any rust, and there's only a slight crack in the dashboard. It looks good, from the outside, has done 124,000kms only.
Current car:
2016 Ford MD Mondeo Titanium EcoBoost (2016-)
Previous cars:
2005 Ford BF Fairmont (2006-2019)
1989 Ford EA Falcon GL (2000-2007)
1982 Ford KA Laser Ghia (1999-2000)
NX74205 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2017, 03:39 PM   #2
superyob
Default Re: Buying a KE Laser - things to look out for
Had a couple of these back in the day. Reliable cheap transport...
superyob is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2017, 07:29 PM   #3
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Like all front wheel drive’s, check the CV joints, find a parking lot and drive the car in a circle on full lock both ways and listen for any clunks/noises.
Check under the distributor with your finger for oil, there is a o-ring on the shaft that is common for leakage, very easy and cheap to fix though.
Apart from that there is very little to check apart from the common stuff like brake pads, oil condition and coolant status, as for rust just check all drainage areas and make sure they aren’t blocked, like under the door seals on each door and lift up the rear hatch and look in the wheel arch wells which are all very easy to get to while your there check the condition of the gas struts and if they hold the rear door/hatch up ok, they are a very robust and great little car, I’ve had many over the years and never had any major concerns.
galaxy xr8 is online now   Reply With Quote Multi-Quote with this Post
