30-04-2007, 03:10 PM | #1 | ||
i have an AU II and the clock light bulb has blown.
the bulb base (plastic) is slightly larger than the lights in the air-con dial unit (which i have replaced) i have spoken to ford and they say they don't stock them. any ideas where i could find it. I thought it would be a ford genuine part .... ??? |
30-04-2007, 06:13 PM | #2 | ||
Karasu
There's a guy who fixes the climate control dislpays calls his business "Liquidxtal" Ph number is 0412 299 034 he keeps a lot of this stuff in stock I am sure he'd have some, he's based in Melbourne but he will post them.
01-05-2007, 05:01 PM | #3 | ||
i have spoken to 2 ford dealers and neither have a reference number for the bulb, only for the clock itself ($70). NO HELP AT ALL !!
the bulb is approx. $4 and am not keep on paying for shipping from Melboune if the guy you referred to does have it in stock. oh well.... ***** it !! |
01-05-2007, 08:45 PM | #4 | |||
I'm pretty sure that when i replaced mine, it was with one from the dash-cluster, which i think they have a part number for.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
01-05-2007, 10:25 PM | #5 | ||
Club Moderator
i had this same problem, i ended up taking the clock out and taking the globe into a mate that works at ford and we went through the globes till we found one.
i kept the original packet cauz i new some one would want it one day. get ford to try part number AU 10G881 A its description is just a globe. see how that goes. cheers tim |
02-05-2007, 04:48 PM | #6 | ||
Flairs - Truckers Delight
its the same as for the odometer, guaranteed.
03-05-2007, 02:45 AM | #7 | ||
i dont know
my clock bulb has blown, and my mate is an auto elec and he got me one, now i just spend the time and pull centre of dash apart to fix it.
http://www.aufalcon.com.au/auforte |
04-05-2007, 08:55 AM | #8 | ||
i tried part number AU 10G881 A. ($14.40...what a joke)
the bulb was too long and the diameter if the plastic base was slightly bigger nd woldn't go in all the way. Also, the auto electrician says that it is not the odometer. So i left the bulb with the lecy and he will try again. So much trouble for such a little thing. Fu#$@%&$#k |
04-05-2007, 10:06 AM | #9 | |||
Club Moderator
04-05-2007, 09:39 PM | #10 | ||
You can definately buy a bulb from Ford for a couple of bucks at most unless it has been discontinued recently. Take the old one in and say get me one of them. From my experience what part number is on the packet at Ford is not necessarily what is inside the packet, especially for little things like bulbs and clips.
04-05-2007, 09:53 PM | #11 | |||
spoolin!
try part ER 10B765 D (should be about $5) its the same as an odometer globe
Current Ride - 2016 FG-X Falcon XR6 Turbo Manual. Smoke Grey Previous Rides - 2014 Black Mica PX XLT Ranger Dual Cab 3.2 Diesel 2011 FPV GS 315 Sedan. Sunburst, manual, fully optioned. Build #165. My 1955 Ford Thunderbird Project (A tribute to my late mother) - 1955 Thunderbird Build Thread
06-05-2007, 12:21 AM | #12 | ||
if you have a sample perhaps jaycar
07-05-2007, 10:16 AM | #13 | ||
CRISIS OVER. he he
i left the clock and bulb with the lecy and he found a bulb with the help of Ford. don't know details of the bulb but it's done. thanks for everyones input and ideas. |
13-10-2010, 05:28 PM | #14 | ||
on the au2 clock,mine does not dim when the lights are switched on ,it just goes out ,is this normal or do i have a problem some where.
13-10-2010, 08:23 PM | #15 | |||
AU Falcon Man
Cheers Cam
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
13-10-2010, 10:31 PM | #16 | ||
Cat be Still !!!
My clock globe has just recently expired...........How do you get the clock out?
14-10-2010, 06:25 PM | #17 | ||
firstly remove the radio,then remove 2 screws,take out the ashtray.remove 2 screws.give the facia insert a decent pull and the clock is held in by 2 screws.note radio can be a ***** to get out,I used coat hanger inserted into the 4 holes and it needs a lot of jiggling from behind.good luck
14-10-2010, 07:01 PM | #18 | |||
these days i wouldn't have the foggiest
21-05-2015, 06:09 PM | #19 | ||
Do you have to go Ford to get the clock light??
My clock just cut out today. So was wondering where are Places you can go to get them? |
22-05-2015, 12:35 PM | #20 | ||
22-05-2015, 03:55 PM | #21 | ||
Spanner Thrower
I'll have to pull my clock out and re-check, but I think it's a t4 bulb. I'll double check tomorrow.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
