Old 19-01-2015, 10:09 PM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Ford capri gt 1972 front brakes
Hi all
just need some heads up. The fron tbrakes on the capri after doing overhall with new pistions and rubbers . When putting back toghter . Should you lube the pistion inside when putting pistion back in . Whats the steps and the right steps i really need this issue needs to be sorted out by stopping at places ....anyway if anyone has beter plains please responded
cherrs
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2015, 05:22 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Ford capri gt 1972 front brakes
the caliper cylinder wall has to be very clean no scoring //like new
..and the piston (you have new )
you use rubber grease to rebuild the calipers kits (red stuff )
metho /brake caliper cleaner to clean the caliper parts
wet and dry paper helps as well
make sure the bleeder is clean also
you may consider painting the calipers with heat resistant caliper paint
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2015, 08:54 PM   #3
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Hi
dirty hands
i get all that but when pistions go back in the caliper is there a lub i mean that goes in the same time to make it slide in and out better..
So it will not frezze on me with time. As i dont drive the car that offen .
Old 29-01-2015, 10:20 PM   #4
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Hi all
has anyone done this before. Well i say smear some brake fluied in side ..
Anyone else think of some thing else
cheers
Old 30-01-2015, 11:03 PM   #5
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
You'll be right smearing some brake fluid inside to slide the piston into the caliper. The piston will be constantly exposed to fluid on the inside once it's been bled. It's only if its left without fluid, or fluid that's old and probably contaminated with water that it might start to seize.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is offline   Reply With Quote Multi-Quote with this Post
