14-12-2014, 11:02 AM | #1 | ||
Hello everybody, my AU TICK XR8 occasionally has a knock when starting, 6 or 7 knocks which at 1st I thought was coming from the front of the motor but not so sure now as I done the arm stretch and started it whilst the hood up standing beside the car and this time it sounded like it was coming from the bellhousing. Question, does the torque converter have parts inside that would knock if the auto trans was low on oil??? Thanks for reading. George
14-12-2014, 12:09 PM | #2 | ||
Au Falcon = Mr Reliable
Imo its something a couple of expert's should listen to George, hopefully someone with more experience can chime in & advise you asap. Maybe do the stethoscope trick with a long metal rod & have a listen with it up against your ear & resting on the bellhousing? Sure its not your camshaft synchronizer? Sorry i coud'nt help more, good luck!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
10-01-2015, 03:02 PM | #4 | ||
Found the cause of the knocking. Oil filter clogged up! Thanks for the help. George
10-01-2015, 03:05 PM | #5 | ||
So how long since it had an oil change/filter
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
12-01-2015, 09:47 PM | #6 | ||
When I spoke to my son & asked him, he told me that it was new when he parked the car under a pine tree FOR 5 BLOODY YEARS!!! Jesus!!!
