Old 16-08-2014, 04:53 PM   #91
burnz
VFII SS UTE
burnz's Avatar
Default Re: Holden to build world fastest ute.
Originally Posted by Bucknaked View Post
And they will stick chev badges on them and still call to the fastest Holden ute.
show me one HSV with a chev badge!!
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2014, 06:39 PM   #92
DJM83
Barra Turbo > V8
DJM83's Avatar
Ask and you shall receive
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 16-08-2014, 06:51 PM   #93
burnz
VFII SS UTE
burnz's Avatar
wow I stand corrected, just wow..
GO SOUTHS
Old 16-08-2014, 06:53 PM   #94
DJM83
Barra Turbo > V8
DJM83's Avatar
your sarcasm detection meter broke.
Old 17-08-2014, 01:04 PM   #95
1TUFFUTE
1TUFFUTE's Avatar
Originally Posted by 40RDT View Post
The bta result doesnt really surprise there is a vid of them getting under 260rwkw out of a 335. Maybe they fudge the base reading to make their gains after mods look more impressive
You questioned me....I gave you the result you were looking for after looking for about 1min. There are plenty of other examples you could try n shoot down like a loyal hsv fanatic but you can do your own research.
Post what you find too
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 01:06 PM   #96
1TUFFUTE
1TUFFUTE's Avatar
Where are you getting those figures from? Can you post some links? I haven't seen one yet under 300rwkw
Cough cough
Old 17-08-2014, 01:20 PM   #97
40RDT
40RDT's Avatar
You gave one example which is questionable to say the least considering they also have a video of a 335 GT with 260rwkw
If there are plenty than post links, cant be that hard for you to do since you seem to have found plenty of examples.
FG XR6T Ute
300rwkw
40RDT is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 03:59 PM   #98
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Ok I'm going to stop your trolling right their starter motor do some research on rwkws for these new GTS. I hope you didn't buy one and had your heart set on anything much more then 300rwkws......because there are guys with 430 GTS getting UNDER 300rwkws! FACT
There are many blokes also getting over 300rwkws...
FACT
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 04:34 PM   #99
Sioso
irregular member
Sioso's Avatar
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 06:57 PM   #100
2242100
As I've indicated in previous posts, tyre slip can cause low Dyno numbers. But also in the case of cars with an overboost feature, perhaps it may not always be working.
Last year I got a tuner to Dyno test my standard FG XR6T on his Dyno with a specific request to tie it down and treat it exactly the same as he treats these cars when he does a baseline power test immediately before tuning them. I also asked him to see if the boost and AFR was the same as the other standard cars.
The result was just 7 kW more than the stock car he had tuned the week before (quite possibly mainly accounted for by my new tyres reducing slip and some weight in the boot).
Also the boost and the AFR was the same as the other cars.
However importantly, the boost was 1.5 - 1.7 pounds lower than in two previous Dyno tests that my car had, and the power reaching the wheels was lower.
So the overboost feature obviously didn't work in this case, and clearly (in my view), this tuner hasn't been getting true baseline figures on these cars prior to tuning them. I believe that my cars engine and transmission was cool and he wasn't aggressive enough.
I wonder how many other tuners make the same mistake?
2242100 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2014, 11:50 AM   #101
1TUFFUTE
1TUFFUTE's Avatar
FACT
Read what I said.....I said "not much more then 300... With some getting less then 300". Average seems to be as low as 315ish possibly a bit more.
As for the guys looking for more -300rwkw GTS.....you allready said there were NONE....I showed you one......in less then minute. And that's all the time I'm willing to give your useless argumentative rubbish when you know how fickle dynos are.......and that most people wouldn't even blink twice if told there are GTS with under 300 as most only dyno just over anyway. Plus like I SAID I'm on an iPad n can't post links. Stop trolling.
Old 18-08-2014, 12:01 PM   #102
Polyal
The 'Stihl' Man
Polyal's Avatar
I saw a beauty the other day, red SS with Chev badges and the 307 clubsport numbers. Sure it might be modded to 307 but still, Chev badge fail.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 18-08-2014, 03:35 PM   #103
b0son
less peak power, more weight, still quicker....
b0son is online now   Reply With Quote Multi-Quote with this Post
Old 18-08-2014, 03:36 PM   #104
Alan D Segal
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Good contributor.
Originally Posted by T.O.Wallace View Post
Yeah, just like XR8 bonnets on 6 cylinder falcons!
Alan D Segal is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2014, 03:39 PM   #105
Chopped
as in chopped
Chopped's Avatar
And GT Stripes on XTs....
-> Reading this signature was pointless <-
Chopped is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 02:09 PM   #106
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Originally Posted by GCRXR6 View Post
Really...who gives a toss if it is the "Fastest ute" .... Stupid really.. What's the speed limit again? Besides, isn't a ute supposed to be a work horse?
Commo utes stopped being workhorses when they put IRS in the rear.
(I know VY 1 tonner and the crewman were leaf sprung)
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 03:09 PM   #107
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Chuck some 2.7 diff gears in a pursuit ute and edit out the speed linmiter.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 05:34 PM   #108
burnz
VFII SS UTE
burnz's Avatar
coil spring can take just as much if not more weight than leaf setup!
GO SOUTHS
Old 19-08-2014, 07:03 PM   #109
1TUFFUTE
1TUFFUTE's Avatar
Yeah that's what I thought too....but it's not great on the tyres tho or something......I think.
Old 19-08-2014, 07:52 PM   #110
Nikked
Oo\===/oO
Nikked's Avatar
Don't see many with a load though...tradies love the falcon tonner though! IIRC, the VFACTS numbers place the Falcon ute close to the Commodore ute (if not higher in same months), regardless, the percentage of Falcon utes sold to commodore sedans is higher.
Probably see the odd CUB with a LSA Maloo carrying some concreting gear and a Staffy in the back.
\≡≡T≡≡/
Old 19-08-2014, 07:57 PM   #111
burnz
VFII SS UTE
burnz's Avatar
springs still handle weight..lol
GO SOUTHS
Old 19-08-2014, 08:19 PM   #112
Nikked
Oo\===/oO
Nikked's Avatar
Handles like she's on rails mate.
\≡≡T≡≡/
Old 19-08-2014, 08:47 PM   #113
nstg8a
3..2..1..
nstg8a's Avatar
What's the payload difference between a pursuit/gs/f6 ute and a maloo?
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 08:57 PM   #114
burnz
VFII SS UTE
burnz's Avatar
50 kg I think going off STD
GO SOUTHS
Old 20-08-2014, 10:12 AM   #115
vztrt
vztrt's Avatar
Not for long periods of time. The sporty Falcon utes are more limited by the tyres then the suspension. Commo ute is not a work ute IMO.
Daniel
Old 20-08-2014, 03:57 PM   #116
Blue Roo
Agreed!
The Falcon Utes are work horses. While the Commodore Utes are show ponies.
Blue Roo is offline   Reply With Quote Multi-Quote with this Post
