[ON DUBS]
does an ED rocker cover need to be removed with a torque wrench?
cheers
BA MK2 XR6T |
You don't need a torque wrench to remove anything. If you're going by the book you need one to put it back on, but if you know what you're doing you don't.
[ON DUBS]
i'm just interested in giving it a new coat of paint and would like to remove it and do a good job.
however i've been told that it has to be taken off and put back on with a torque wrench so that the head isnt damaged.
BA MK2 XR6T |
Diabolus
torque wrenches are only made for tightening bolts not undoing them. just use a spanned and be careful not to squash the new gasket to much when tightening it back up, they dont need to be super tight.
#5 | |||
Once PHASED.
2006 BF XR8 Bionic. |
Formerly XG-Panelvanman
make sure when u put it bak on the gasket on the rocker cover doesnt come off or move when u put it on
this will result in an oil leak which i have at the moment
My Ride: BA MK2 Wagon, dedicated LPG, white. modifications: cargo barriers, tow bar |
[ON DUBS]
is it possible to damage anything by taking it off and putting it back on?
BA MK2 XR6T |
ummm no,except
2000 AU Wagon |
#9 | |||
they call me Tibbo
#10 | |||
[ON DUBS]
time for painting! :sm_headba
BA MK2 XR6T |
*Smart *** comment here*
dont forget to fully clean it, else all those bits of burnt gasket on the head will cause oil leaks... use a razor and some 2000 wet and dry, bought the el up like it was chrome... no leaks so far!
1997 4.0L EL Falcon GLi Sedan Auto ---------------------- 2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe Lowered all round on King Spring Super Lows Tinted Windows, Pioneer MP3 Player and Audio System K&N High Flow Air Filter Mounted in Original Air Box Trip Computer NGK Sports Performance Leads NGK Sports Plugs Autotecnica Oil Catch Can
GMHKLA number plates
u should never undo with a torque wrench they stuff up like that
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph ![]() 2000 Honda S2000 14.73@92mph (stock + no traction) ![]() |
