Old 25-01-2006, 04:43 PM   #1
Simmo
White Lightning
Simmo's Avatar
Default QLD exhaust decibel testing method?
a mate of mine works at an electronics shop and has agreed to let me decibel test my new exhaust with their awesome gear. what i would like to know is the proper police testing methods so i can get it right and see if i need to make it legal. i know there's a certain distance and angle it has to be on, not just shove the mic in the pipe.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:45 PM   #2
347Stroker
347Stroker's Avatar
Bring it around to my place,
Add 1 carton Tooheys New 30 pack Cans
Consume Cans
Let Cans settle for 1/2 hour
Get in car and rev the sh1t out of it for 3 minutes
If the bible bashers next door dont turn on their lights, it can be louder....
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:49 PM   #3
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
rpm equal to 2/3rds of where peak power is made (i.e. if peak power is at 15,000rpm (yours is. trust me.), then it's tested at 10,000rpm). The mic is 6 feet from the tip of the pipe , on an angle away from the car (i.e. if the pipe is on the RHS, it's 6 feet diagonally to the right of the pipe).
90% sure that's correct.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:57 PM   #4
Simmo
White Lightning
Simmo's Avatar
sounds like a plan. anyone actually know the legal limit on cars? 88 and 90db ring bells in my head. never had to worry about all this with the super-mega-50 mufflers and a blocked cat system that was on there.
Old 25-01-2006, 05:06 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
the guys were testing some new gear at Zillmere mainroads one day and I asked them what it was.. It was the new tester... It is a foot by foot triangle on a foot tall tripod with the mic on it.. hard to explain but it is a foot away from the tail-pipe on a 45 degree angle and a foot off the ground
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 05:44 AM   #6
EvilChief
Boost Addict
45degree angle and 1m away toards the opposite end of the car from where the exhaust is located (ie exhaust is on RHS, device i head at 45 degree horizontal and 1m away and same distance off ground as exhaust pipe towards LHS). RPM = 2/3 of max rpm, ie max rpm at 6000rpm = tested at 4000
thats how the cops showed me when i asked them to explain it to me
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 07:41 AM   #7
jabba
jabba's Avatar
90% correct, YES..... the rpm you need to be tested at is 4000 rpm, regardless of your rev limit (unless of course you car dose not rev to 4000)
mic is 6 ft to the side of your car at a 20 deg angle back. (i.e. if the pipe is on the RHS, it's 6 feet diagonally to the right of the pipe angled back 20 deg). if you have a pipe coming out on both side of your car (like new GT) you will have to conduct the test twice. Once on each side of your car....
An interesting note. When testing you do not take into account the back off gurgle you exhaust make when you get of the peddle.....
Built by HERROD MOTORSPORT
Tuned by Elite Automotive
11.91 @ 117mph Vid
jabba is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 10:00 AM   #8
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Well, if anyone gets pinged using that equipment, I'm pretty sure its able to be fought, from memory its too close to the pipe and will cause inaccurate readings due to near field effects (Been a while since i did noise and vibration type accoustics, but recall that theres a minimum distance for measuring based on the lowest frequencies expected to be found). This is from an engineering standpoint, not department of transport bullИИИИ rules.
Sweet. this means that my RG is barely above idle if/when it gets measured.
Anyone 100% on the sound limits? bikes 96db(a)? Pre 90 something cars 92db(a)? newer 88db(a)?
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
