Old 25-01-2006, 04:18 PM   #1
foxtrot
Blood, sweat & tears
foxtrot's Avatar
Default Car rubber - Weather seals
This is the email i got from Scott at
www.scottsoldautorubber.com.au
:weather seal inner and outer and not available yet.:
225.037 $43.87 boot
322.040 - NLA
240.063 $9.96 ea pedal
240.105 $14.19 ea pedal
240.065 $9.39 ea pedal
613.008 $9.10 each glue
+ freight.
thankyou,
Scott.
The highlighted bit is the part i need most.. The rubber bits that go on the top of the door trims that the windows rub on and the strip that goes on the inside of the door for the outside of the window to rub on
anyone know anywhere else I should look to get these (door trims are off and the rubbers have split so I really need them)
foxtrot is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:20 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
just fit ef/el weather seals (from a wrecker), are alot quiter then EA-ED for a start.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 04:57 PM   #3
foxtrot
foxtrot's Avatar
Are they cheap
Can you get them new
