14-01-2006, 04:49 PM | #1 | |||
AFF's 1st DM.......
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Ok Fordfans Im in need of assistance.
I have recently bought a 160gig h/d for me comp as the old one is full and is only 40gig. Alrighty, i have set the new onto slave i believe and have connected the power and ribbon cable. So what now? If i go into my computer its doesnt show up as me other "C" drive does, If i go into control panel, system and Device manager it shows up underneath the original drive but how do i store stuff on it, there seems to be no dramas nor is there a yellow exclaimation mark : Help.......
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
14-01-2006, 05:21 PM | #2 | ||
Formerly au^ute
click start, then run, then type in diskmgmt.msc and click ok
Find the new drive in there and creat a partition on it then format it. a wizard may pop up, may not. |
14-01-2006, 05:29 PM | #3 | ||
Looking for clues...
Did you change the BIOS settings to tell the computer that it has a new drive to look at?
14-01-2006, 06:07 PM | #4 | |||
striped
control panel -> administrative tools -> computer management -> storage -> disc management thats how i did it for my other hdd |
14-01-2006, 06:08 PM | #5 | |||
AFF's 1st DM.......
Errr set bios as primary slave.. for that h/d
14-01-2006, 06:17 PM | #6 | |||
AFF's 1st DM.......
ok ok ...
how would one utilise the 40 gig h/d for like windows xp pro programs and the like, and just leave the other for pics doc etc...
14-01-2006, 06:33 PM | #7 | |||
Just copy as much of the junk ie pics docs etc. over to the new drive. Save everything to the new drive from now on. |
14-01-2006, 06:36 PM | #8 | |||
AFF's 1st DM.......
Thankyou Fellas.... Muchly appreciated.
14-01-2006, 09:03 PM | #9 | |||
Formerly au^ute
15-01-2006, 01:53 AM | #10 | |||
Initially I thought this might be a compatibility issue, but as I read down the posts it's all sorted and seems it all works, but one thing for others sticking newer larger hard drives in older computers - check the motherboard supports drives of that size. My mate has an NForce2 motherboard with an AthlonXP 2500+, so it's not that old but it supports a maximum of 120GB only - with no further BIOS updates available. At the time of his last hard drive purchase, we were looking at getting a 160GB drive - had to downgrade that to ensure it was supported.
15-01-2006, 05:35 AM | #11 | |||
15-01-2006, 01:28 PM | #12 | |||
striped
nope, found it now |
15-01-2006, 02:38 PM | #13 | ||||
16-01-2006, 09:39 AM | #14 | ||
Go on, be a monkey....
Did you set the jumpers on the 2nd HDD to be slave?
16-01-2006, 11:40 AM | #15 | |||
AFF's 1st DM.......
Yes mate, what would happen if i set them both to master?
16-01-2006, 11:58 AM | #16 | ||||
18-01-2006, 11:56 AM | #17 | ||
Posts: n/a
If you have a problem with the OS not wanting to recognise a large HDD because of hardware limitations or whatever try going to the HDD manufacturers website as most have a small downloadable utility that lets you trick the pc into accepting the larger harddrive.
If both HDD's are set as Primary Master you would be lucky if the pc started at all. |
18-01-2006, 08:20 PM | #18 | |||
Undergraduate EB Operator
Simon ----------------------- 04 BA Xr6 ... now with carpark dints ----------------------- |
19-01-2006, 02:52 AM | #19 | ||
Posts: n/a
Yes, very true.
