Old 17-09-2013, 01:41 PM   #1
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Engine from a generator into a vehicle?
Hey guys, I've got the opportunity to buy a 5.9L Cummins 6BT from a train fairly cheaply, they have been used as a generator from what I've been told.
These engines were also used commonly in Dodge RAM in the USA, is there any legislation that would be holding me back from using it in a vehicle?
Its a common conversion for those big American utes like F series/Silverado/RAM etc.
So far the differences are fuel pump I'm fairly sure, the rest of the engine is the same as the automotive version.
The year of the engine is 2003 ranging up to 2009 of the ones I have been offered, the vehicle in question is 2000/2001.
Old 17-09-2013, 02:35 PM   #2
xisled
Default Re: Engine from a generator into a vehicle?
My guess you would have to get the car engineered and to pass all EPA requirements. Maybe speak to Vic roads or an Engineer.
xisled is online now   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 02:43 PM   #3
Franco Cozzo
Thailand Specials
Even though the vehicle in question is diesel already and fitted with an engine of larger capacity?
Are there any engineers in Victoria who I can call to ask about this?
Old 17-09-2013, 03:06 PM   #4
wodahs
wodahs's Avatar
I think xisled is suggesting and I believe it to be so over here that even tho the vehical still runs the same type of fuel being a newer type vehicles motor it may need to comply to newer emission regs , and another thing you may need to look at is if its a larger capacity motor you may still need it engineered as well
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 03:16 PM   #5
Franco Cozzo
Thailand Specials
Ah yes, I get what you mean. I'll talk to the engineer we use at work for our vehicles and hopefully he can advise me further, is it just a normal automotive engineer I have to talk to or are there specific ones for example engine conversion engineer?
I'd be going down from 6.5L V8 to 5.9L I6, both turbo diesel.
Old 17-09-2013, 03:17 PM   #6
JG66ME
Technical Contributor: For members who share their technical expertise. - Issue reason: Great tech articles and assistance to all in the Classics arena.
Industrial engines, especially those used on Alternators, are set to a constant speed with a governor quite unsuitable for automotive use. They are usually set to a fixed 1800 rpm and they maintain those revs as load increases and decreases. Where as the truck version my rev to 2700 rpm this version may be lucky to get to 2000 rpm.
If I was you I would investigate the pump differences, if any, as getting the correct pump could be very expensive and it is likely that you would be able to modify the pump fitted to that engine. You need to speak to a Cummins expert. It may be possible to set the pump for automotive use.
My knowledge of Automotive vs Industrial and Tractor diesel engines is limited to Ford 590E, Ford Dover and Ford Dorset. I have twelve of them, lol.
Steven
JG66ME is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 03:51 PM   #7
Hulsty
Cam shaft could be different to suit the RPM range too.
The Silver Bullet - BJ74
Where the actions at Ontrack 4wd Club
https://www.facebook.com/ontrack4wdclub
Hulsty is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 03:55 PM   #8
Franco Cozzo
Thailand Specials
Steven
Currently investigating at the moment, so far we've established the industrial versions of them MAY be common rail, with the gear driven pump at the rear not suitable for automotive use. There are multiple industrial versions of this engine.
You are right about the pump, they spin at X RPM, so the pump will no doubt have to be changed.
I've got pick of about 30 engines so far.
On this one the pump appears to be at the front of the engine, but look at the oil filler neck and dip stick:
You could extend those to be up the top, right?
Old 17-09-2013, 05:06 PM   #9
2011G6E
2011G6E's Avatar
Steven
Bingo...beat me to it. Guys have found the same problem (narrow rev range) in the past building specials using airplane engines like Continental flat sixes out of old Cessnas...they're powerful, yes, but they're built to run pretty much in a narrow band of revs. Generator engines, even more so. They're designed to run at one speed, give or take a little, where they are most efficient.
Good luck with it though...
Old 17-09-2013, 05:58 PM   #10
JG66ME
Thing about AC alternators is the engine speed affects the frequency and voltage so they design the gen set to run at a rev range that the engine can maintain constant revs, typically at maximum torque.
My experience with the Ford engines I play with is they are used in trucks, tractors, industrial (compressors, pumps, combine harvesters and gen sets) and boats.
All have different speed control requirements.
Old 17-09-2013, 06:00 PM   #11
wrongwaynorris
wrongwaynorris's Avatar
Generators in Australia with a 4 pole alternator will run at 1500 R.P.M to maintain 50 cycles ( Hz ) . They will have a fixed speed governor but it is a relatively simple exercise to change to a multi speed . Also if it has an Isochronous governor as many generator engines do remove that also . Any good pump shop will know how to do all this . here is the rub however as Generator Drive engines are designed to only run at one speed many have different cranks , conrods and camshafts as they do not need to respond like a multi speed engine .
Chevy badges , the Polariser of the new millenia .
wrongwaynorris is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 08:31 PM   #12
CAMS290
trying to get a leg over
CAMS290's Avatar
That is the 1st generation 6BT Cummins which is full mechanical and uses a Bosch rotary pump, the later type were the ISB which used a Bosch high pressure pump and different injectors and the latest type is still a ISB but uses common rail and full electronics.
Would be easy to change that from industrial to automotive spec I rekon.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2013, 08:34 PM   #13
CAMS290
CAMS290's Avatar
U can change the oil filler and dipstick locations easily, these motors were made to fit a variety of things, case tractors had them fitted, Blaw knox asphalt pavers had them too.
There should be a aluminium tag on the top of the timing cover with the specs on it.
Cameron
Old 18-09-2013, 09:21 AM   #14
Franco Cozzo
Thailand Specials
Might be the goer I reckon, these mechanical diesels pretty much just need power to their fuel shutoff solenoid and thats about it to get her running.
So minor modifications and she will be good to go, I'm seriously considering purchasing one as i can get it for a real good price.
Even if it doesn't go into one of my cars for a while, its a good project.
Old 18-09-2013, 06:21 PM   #15
351EL
Damo I'm looking at these also.
If you swap the rotary pump for a p pump you have to change the injectors too they operate at different pressures.
351EL is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2013, 06:41 PM   #16
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
How many hours have these engines clocked?
What do they want for them?
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2013, 12:24 PM   #17
Franco Cozzo
Thailand Specials
The 2003 models are $1750 with one rebuild already done up to $2650 for a 2009 model with no rebuilds.
Old 19-09-2013, 03:44 PM   #18
Franco Cozzo
Thailand Specials
Here is a pic of prices:
I put down cash on a 2003 one, so minus 1 from the list
I can give you contact details via PM if anyone is interested in one.
