cabx
Hi guys,
Having a problem with interiors lights not working at all, as well as key light. Have checked all the fuses and they seem to be fine. I would appreciate any suggestions, as I am at a loss. Thanks CABX - Frank. ![]() |
Flairs - Truckers Delight
sorry to post the obvious, but have you replaced the bulbs?
perhaps the car isn't picking up that a door is open, does the red door sign show up when you open a door? try different fuses - i had a fuse one time that looked fine but when swapped the problem followed the fuse. and by interior light i assume you're meaning the roof light and perhaps lights above the rear doors or near the sunnies holder.
cabx
Thanks,
Sorry i took so long to reply.I've checked all bulbs replaced the one for the ignition. Checked and replaced both fuses 10 & 11 but still no joy.Ill just have to keep looking. thanks again......frank |
Had you recently d/c'd the aircon or had a problem with it? Workshop manual says a controller by the passenger-side (thru glove box) may need checking if cargo/boot light, map lights (interior light) and door switches (interior light) do not operate even after their bulbs have been checked. Last on the list after a faulty Ground between the offending light (so if its all of them, the controller) and mentions the window defroster in that mix as well.
Good luck. |
