15-07-2013, 10:36 PM | #1 | ||
hi
what is required to register a homebuilt teardrop caravan in sa and does the chassis need engineering and can the chassis be engineered before the timber walls and roof put on. someone said the homebuilt caravans or trailers have to be engineered by a engineer does the chassis have to be engineered with the walls and roof or can just the chassis be engineered before the walls and roof go on. is it possible to just weld a number on the drawbar and say its a old caravan with same owner or unknown owner and/or theres no number plate and needs a new rego number or even moving the number plate over fron a rusted out caravan and just tell them you repaired the chassis to minimize problems getting a homebuilt chassis registered to minimize problems with the gas and 240v can you register it first then get them done if you make up a number for the chassis and say its a old vehicle Last edited by car10002; 15-07-2013 at 10:48 PM. |
16-07-2013, 07:17 AM | #2 | ||
For your own peace of mind,and everyone else's.
It would be best to have it engineered and certified. |
16-07-2013, 07:57 AM | #3 | ||
It's just a closed in trailer so it's registered as such weigh bridge cert and blue slip and away you go
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
16-07-2013, 08:08 AM | #4 | |||
RIP...
Caravans are classed the same as a box trailer. The gas will need inspecting by a gas dude though.
. Oval Everywhere... |
16-07-2013, 08:49 AM | #5 | ||
Cheers, Sam. |
16-07-2013, 10:01 AM | #6 | ||
have a look at this it tells you what is required
LOOK AT ME hope that helps as for the gas side you can get hoses and the likes made up to suit what you need Jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
16-07-2013, 10:14 AM | #7 | ||
What about if the trailer or caravan has a chassis number but no number plate and was made before 1989 or if it doesn't have a chassis number or rego plate and is a pre 89
16-07-2013, 10:46 AM | #8 | ||
Ring the dudes at Regency Park.. the answers you seek are not here....
16-07-2013, 01:14 PM | #9 | ||
R51 Pathy, 91 Jayco Swan
I yelled out the window to some Grey Nomads on the way past. They didn't have a clue what you were on about. ?????
16-07-2013, 02:45 PM | #10 | ||
No inspections required if you do every thing with 12v. If you want a gas stove try a metho burner.Plenty hot and safer.
16-07-2013, 06:32 PM | #11 | |||
I've personally done electrical work through work that set a vehicle on fire, luckily only an engine bay fire, melted a battery, burnt up the pollen filter housing and destroyed some wiring, rather than total loss of vehicle. It doesn't take much. |
16-07-2013, 09:48 PM | #12 | |||
Performance moderator
Not so grey though... Lol.. Bought a converted Fuso bus..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
