05-12-2007, 04:51 PM | #1 | ||
Falcon Unbelievable
Im putting an EB auto trans into my au, we can't get the bell housing off either off them because u need a special tool....
Should we just keep the EB transmisson bell housing or try and actually swap them over? Will it actually matter? |
05-12-2007, 04:56 PM | #2 | ||
why not put a 4.1 crossflow in as well to completly downgrade the car? the EB tranny although a BTR is different and a backward step if you need to replace the tranny get an AU one
05-12-2007, 05:14 PM | #3 | ||
Falcon Unbelievable
............Help please.......
05-12-2007, 05:17 PM | #4 | ||||
Back to Le Frenchy
05-12-2007, 07:36 PM | #5 | ||
Are the torque converters and bell housings the same? If so, then you should be right just to bolt it up. If not, then you will need to change them over.
.........me wonders why you would attempt this if you don't know what you are doing!!!!
05-12-2007, 07:37 PM | #6 | |||
06-12-2007, 12:00 AM | #7 | |||
Falcon Unbelievable
06-12-2007, 12:59 AM | #8 | ||
Young !@#$ Head
The ECU wont run it... It should bolt up no worries but in the manuals the input shaft on the E-series is longer this might be the case with the auto as well im not sure i've never heard of anyone doing it??? the E-series box changes gears so slow and is a of a gearbox but hey if ya want to do it you probably could i dont see why but you will have ECU problems as the AU's ECU, IIRC is a one piece unit engine and gearbox were as the E-series has one for the box and one for the Engine i could be wrong...Have fun
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
06-12-2007, 09:02 AM | #9 | |||
06-12-2007, 11:08 AM | #10 | |||
07-12-2007, 01:42 AM | #11 | ||
Hey mate i had an eb trans n stall in my au. The bel housing bolts are just a socket. Straight from ya standard set. U just have 4 instead of 8 bolts holding it there. Mine went fine. But it wouldnt engine brake in 1 2 or 3 and it would intermitently stay in drive. And wouldnt reverse. I think they were other issues NOT RELATED to it being in an au. As the gbox shop never mentioned anything when i asked about the issues i had.
08-12-2007, 04:45 AM | #12 | |||
Falcon Unbelievable
We've already installed the auto using the eb bell housing lol.... |
08-12-2007, 09:03 AM | #13 | ||
So everything is ok? Least she bolted up with the eb bellhousing!
08-12-2007, 01:30 PM | #14 | |||
Falcon Unbelievable
08-12-2007, 04:01 PM | #15 | |||
10-12-2007, 04:50 AM | #16 | ||
Falcon Unbelievable
Yay auto is working very well! Shifts great, a little loose but will proberly need a auto service! But for $50 im not complaning! The car goes even harder then before in 1st and 2nd and even 3rd! Im loving it!!!
Got the whole job done including the price of the auto for all under $200! Thanks everyone for your help too! |
10-12-2007, 11:40 AM | #17 | ||
AWESOME to hear mate!!!
i bet you were feeling very unsure with all the negative comments above before i came along eh hehehe hope she holds together for a while for ya till u get it serviced is yours real tight in the shifter department?? my EB box was hard to move the gear selector but on the AU box its real smooth and soft sorta thing
10-12-2007, 08:09 PM | #18 | ||
What was the issue with starting it?
10-12-2007, 10:34 PM | #19 | ||
he started a different thread..
turned out to be an engine bay fuse marked ENGINE replaced fuse and worked fine
11-12-2007, 01:54 AM | #20 | |||
05-06-2013, 06:40 PM | #21 | ||
Hay guys I have just got a ED ford falcon today it is not going into gears right it just keeps slipping its alright when its cold but after 2 mins it just starts slipping and its smooth nothing hard no bang's just sleeps could it be the torque converter or id the gearbox just ****** any help would be nice tyvm
05-06-2013, 06:53 PM | #22 | ||
meh.
I'd say your fluid is low. Service it (filter and fluid change) and it should be good.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
06-06-2013, 04:51 PM | #23 | ||
alright I will give that a try thanks
20-06-2013, 04:16 PM | #24 | ||
yep that seem to have done it the filter was that blocked it could not get any oil in it but now it seems to make a bit of a knock when its changing gears could it be because of all the old oil in it >??????
