Old 15-03-2012, 01:10 AM   #1
au adam
au adam's Avatar
Default Fitting Crank angle sensor.
Hey guys,does anyone know how diffucult it is to change the crank angle sensor on an AU 6?basicly need to know what needs to be removed for me to get to it.
Thankyou in advance.
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 11:36 AM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Default Re: Fitting Crank angle sensor.
Pretty easy mate, 1- (optional to remove fan shroud & fan pack for better access, takes only a couple of minutes) clean area, unplug connector, 2- undo & remove 2 x 6mm bolts, 3- slide out old cas remembering which way it come out, 4- slide in new one, bolt up and plug in,(reinstall fan shroud & fan pack) remove any tools or rags and start car. Good luck with it.
cheers ,Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 10:08 PM   #3
au adam
au adam's Avatar
Thanks Maka,will give it a go on the weekend.
Old 13-06-2013, 12:15 PM   #4
Robbimj
Can anyone tell me the volts of the CAS 99 au series 1 xr6
Robbimj is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2013, 12:51 PM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
VRS crank sensor-
Input will be bias voltage - 5v.
If you are back-probing you will read the resistance of the sensor so it will be under 5v.
Output will be an AC sine wave that is best read with a graphing scope. Voltage and frequency will increase with rpm.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
