Old 02-12-2012, 10:06 PM   #1
MADED-6
MADED.6
MADED-6's Avatar
Default question about v8 conversion for au.
I want to convert my au to v8.
I have found an au1 Fairmont v8 for the parts (I will rebuild and do cam and a few things to engine before fitting it) but mine is an au3 so my questions.
1. Au1 is smartlock and mine is smartshield so how do I get around this?
Or do I have to get wiring and ecu from an au2-3?
2. I read that au subframe/k frame is the same 6-8cylinder unlike e series?
Any other info I should be aware of?
Cheers Josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2012, 10:40 PM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
Default Re: question about v8 conversion for au.
K-frame is the same Josh.. You will only need to change the mounts..
The easiest way around it would probably be to transfer the ECU, BEM and key barrel from the AU1 into yours, essentially changing it to smartlock..
Even if you got all the S2/3 stuff, it will still need to be programmed, unless you pull it all from the same car..
I did it the other way around when doing mine and went from smartlock to smartshield, to save all the hassles..
If you've got a whole donor car, it's probably your best bet..
EDIT: You also may need to change the oil pressure switch to the S2/3 one though because it's more of a dummy gauge, the S1 one shows actual pressure..
If you have S2/3 cluster you'll need S2/3 pressure switch..
You'll also need to modify your fuel lines, or use the fuel lines from the donor car..
If I think of anything else mate, I'll let you know..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2012, 11:10 PM   #3
MADED-6
MADED.6
MADED-6's Avatar
Nah I was going to buy a donor but don't have the room.
I'd rather wait and get au2-3 than go back to smartlock to be honest.
Thanks mate.
TUFAU-8
Get Stroked.
Old 02-12-2012, 11:14 PM   #4
KR1STO
KR1STO's Avatar
Probably a better option..
If you look around at the auctions, you may be able to find a nice 220kw XR that has been written off..
Then transfer everything across and ebay all the leftovers..
Is yours a high series dash though..?
see my car here:
[SIGPIC][/SIGPIC]
Old 02-12-2012, 11:46 PM   #5
MADED-6
MADED.6
MADED-6's Avatar
Yeah it's a ghia.
May be better to sell up and get a v8 but I like this au haha.
TUFAU-8
Get Stroked.
Old 03-12-2012, 12:00 AM   #6
FGII-XR6
FGII-XR6's Avatar
that won't work you would need to change all the dash wiring as well ( there are some wiring incompatibilities between S1 and S2/3 )so essentially you would need to put a complete S1 dash in big job and a backward step
[SIGPIC][/SIGPIC]
Rides:
Old 03-12-2012, 12:27 AM   #7
KR1STO
KR1STO's Avatar
That's what I meant.. I transferred all of it into mine by changing the whole dash, as it was way easier..
I should have elaborated more..
see my car here:
[SIGPIC][/SIGPIC]
Old 03-12-2012, 09:17 AM   #8
FGII-XR6
FGII-XR6's Avatar
the way you did it , smart lock to smartshield is a positive move, the other way around is a backwards step so he is better off getting the right stuff for his car
[SIGPIC][/SIGPIC]
Rides:
Old 05-12-2012, 12:06 PM   #9
BOTTLEDUP
...or just buy a V8 model.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2012, 12:33 PM   #10
FGII-XR6
FGII-XR6's Avatar
where's the fun in that
[SIGPIC][/SIGPIC]
Rides:
Old 05-12-2012, 02:22 PM   #11
bartsau
bartsau's Avatar
So true!! Having just got my wagon driving again after a v8 conversion I gotta day that it is one of the most satisfying feelings ever!!
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2012, 04:17 AM   #12
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Dash change on an au is a simple job, easiest falcon dash I've done. And for legality you cannot put an older motor in a newer car, i know it's basically the exact same motor but thems the rules.
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
Old 10-12-2012, 01:48 AM   #13
JC
JC's Avatar
Cheers Josh.
I take it this would be for a different car to the one with the stroker in it?
Ford Performance Club ACT
Old 12-12-2012, 11:46 PM   #14
MADED-6
MADED.6
MADED-6's Avatar
Yeah that car is long gone.
It took me a long time to figure out how to do the Sig and avatar so I've never bothered changing them haha.
TUFAU-8
Get Stroked.
