Old 28-10-2012, 02:33 PM   #1
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Exclamation AU I6 cooling system
Gents
The Mrs' bunkie doesn't seem to like hot days now that they're here. Spews a fair amount of coolant out of the header tank overflow. Temp guage doesn't seem to go higher than the 'O' in the N O R M A L writing on the guage, but the amount of coolant coming out suggests something else is going on. Both of the thermofans appear to be working.
I may replace the radiator cap and see if that makes a difference. It has the Ford 120kPa unit on there now. Should I do the thermostat as well? Parked on a level surface with the engine running, the bleeder hose that runs from the thermostat housing to the header tank is working overtime shoving coolant into the header tank - is it supposed to be doing this?
Radiator was replaced by Natrad last year, for the previous owner. I would assume they did a flush at the same, time, the coolant colour looks very clean and blue.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2012, 03:43 PM   #2
Day-mow
rexnet
Day-mow's Avatar
Default Re: AU I6 cooling system
i'd put a thermo in. for $20 you cant really go wrong. but that does sound a bit odd.
check your rocket cover cap and dip stick. see what color the oil is.
do you seem to loose coolant?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2012, 03:48 PM   #3
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
My EA had the exact same problem. It was intermittent at first, then became regular. Turned out to be a blown head gasket. Funnily enough it would only spit out coolant until the engine warmed up, only then would it stop gurgling and spitting from the header tank.
Try warming the car up in the driveway without the pressure cap on and see what happens with the gurgling.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2012, 05:13 PM   #4
Kryton
Kryton's Avatar
Its the radiator cap.
Old 28-10-2012, 09:37 PM   #5
TheInterceptor
Cruising...
TheInterceptor's Avatar
Had the same problem. I replaced the standard 120kpa rad cap with a 130kpa unit from Repco and replaced the thermostat (which appeared to be stuck open) while i was at it. Done this a lil while ago and so far through heavy use and all, not a single drop has come out of the tank
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2012, 10:14 PM   #6
mik
mik's Avatar
you could always drop into one of the tune up places and get them to stick the gas analyser probe into the coolant, if there`s exhaust/combustion gas in there you have a leaking head gasket.
Old 29-10-2012, 09:01 AM   #7
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
My first thought was head gasket. A radiator place will also be able to do a quick test for exhaust gases in the coolant. If anything, a cooling specialist will be able to tell you what is going on. Generally they won't charge for the quick test.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2012, 09:18 AM   #8
Road_Warrior
Pity the fool
Well...if it's the head, then that is the end game for this car. I'm not spending that sort of money on it after what I have had to do to it in the 10 months I've owned it. However it doesn't generally use coolant, it was only after a hot drive under load it did this coolant spewing thing, and I'm thinking its the rad cap.
Old 29-10-2012, 07:14 PM   #9
Day-mow
rexnet
Day-mow's Avatar
lets hope so.
Old 29-10-2012, 09:25 PM   #10
GK
Walking with God
GK's Avatar
A few years ago mine did the same. Replaced the cap and all was good!
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 31-10-2012, 07:22 PM   #11
Ford Falcon XR6
Ford Falcon XR6's Avatar
Had the same problem when i first bought my car turned out to be the cap for some reason someone fitted the wrong one.
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
