Old 25-09-2012, 05:42 PM   #1
buddy92
Default What's this thing called, and where can I get one?
Hey guys. Just noticed the rubber thing between the door and the window on the outside has been split, and don't know what it's called. On the other hand does anyone know where I could source one from please?
buddy92 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 05:49 PM   #2
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Default Re: What's this thing called, and where can I get one?
Weather strip,
Car companies or big parts stores should be able to get them for you..
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2012, 06:13 PM   #3
buddy92
Thanks mate. Shops like Autobarn, Supercheap ect? I'd go to Ford but they usually charge an arm and a leg for cheapish things.
How hard are they to replace?
Old 25-09-2012, 06:17 PM   #4
Smoke Pursuit
You will struggle to match it anywhere but Ford.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Old 25-09-2012, 06:18 PM   #5
buddy92
Oh ok, I'll just go to Ford then.
Are they hard to put in?
Old 25-09-2012, 06:33 PM   #6
jpd80
jpd80's Avatar
Fg is still a bit new, genuine is probably best or only source for now, have a look at the new part
and if you're up to it have a go but if not sure a panel shop can put it in for you..
Old 25-09-2012, 07:17 PM   #7
b2tf
not here much anymore
b2tf's Avatar
cannot get them anywhere but Ford.
2024 F150 XLT
Old 26-09-2012, 10:07 AM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
except the wreckers
Old 26-09-2012, 10:57 AM   #9
zilo
BANNED
zilo's Avatar
It might never fit and seal as well after replacement....(might fail the car wash test )
Sounds backyardish..and silly ...but i would try superglue first.
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2012, 11:07 AM   #10
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Part of the sill trim that extends across the full width of the door. Hardly worth replacing, try superglue as suggested, or black windscreen silicone applying underneath using a thin implement, then holding down with tape until cured, rather than applying on top where you can see it.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2012, 12:07 AM   #11
buddy92
There is now 3 cracks and splits, don't know why that certain section keeps doing that, but I will try super glue underneath first see if it helps.
Old 18-10-2012, 12:27 AM   #12
XF Falcon
[FORCED]
XF Falcon's Avatar
Looks like the belt mould? Easily available through ford spare parts or wreckers.
Ford charges around $50 each from memory for BA/BF's, not sure about FG's.
500 rwhp BF XR6 Turbo and 115 rwhp XF
XF Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2012, 08:28 AM   #13
GlenW
GlenW's Avatar
Is your car under new car warranty still? You might be able to get it fixed under that.
06 BA2 GT-P now has YT CAI, dropped on SL King Springs & XForce Exhaust.Pics here and here
73 Mazda RX2 Series 2 with 12a Bridgeport http://imageshack.us/a/img812/2789/cimg2974u.jpg
01 Toyota Vitz RS - 1500cc vvti, 15" factory alloys, full body kit.
GlenW is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2012, 09:23 AM   #14
buddy92
Nah it's completely out of warranty.
