Old 12-10-2012, 08:57 PM   #1
Middleout
Default Rear wheels fit fine, front wheels studs too short??
Just picked up some 5 slot jelly beans to fit to my ZH, the rears fit fine however the front studs barely make it past the lip of the holes on the rim to get the wheel nut on. They're just standard nuts, not tapered or anything. Has anyone had a similar issue or know how to overcome this? I'm pretty desperate as I need them on for a RWC ASAP!
Middleout is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 09:03 PM   #2
Marquis
HUGE MEMBER
Marquis's Avatar
Default Re: Rear wheels fit fine, front wheels studs too short??
Long shank wheel nuts bud. Bob Jane ect will order them in for you
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure
My cruiser. 1979 Zh Marquis. "T" code 351.
My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1.
My dog. 2011 Sierra
My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue
Wanted
Borg Warner Lsd or centre. 25 spline
Marquis is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 09:06 PM   #3
vanman_75
XD Sundowner
vanman_75's Avatar
getting in first DO NOT DRIVE IT with normal wheel nuts , besides destroying your rims , they will snap wheel studs ...take your standard nut and rim to a tyre dealer they will give you the correct nuts
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 09:11 PM   #4
Middleout
****. So i'm in for a big job then. Any reason why the rears fit but the front dont?
Old 12-10-2012, 09:14 PM   #5
Itsme
Experienced Member
Itsme's Avatar
If I remember correctly with those old wheels the wheel nuts actually go through the hole of the mags.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 09:26 PM   #6
vanman_75
XD Sundowner
vanman_75's Avatar
the wheel stud should barely stick out and the wheel nut goes through the wheel as a firm fit , was going to add a pic.. but i think you will get the idea , look at the rim just sitting on car and see the gap around wheel studs ... that is filled with the correct wheel nut with a sleeve looking bit on it as part of the nut , google wheel nut images and you will see the difference between tapered nut and alloy wheel nut ..
Old 12-10-2012, 09:33 PM   #7
Middleout
the walls of the nut would have to be quite thin though as theres not much room there for the sleeve of the tapered nut.
Old 12-10-2012, 10:05 PM   #8
vanman_75
XD Sundowner
vanman_75's Avatar
yer they are not real thick ... throw up picks or go to tyre place , but definately dont run em if the thread doesnt come right through the nut ...nuts are cheap and they will give you the right ones ..
Old 12-10-2012, 10:17 PM   #9
Middleout
i'll check it out tomorrow, cheers!
Old 12-10-2012, 10:36 PM   #10
JimStone
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2012, 10:38 AM   #11
ado351c
I've got dragways on the EF and i found i needed 2 washers.
Previous Rides,'78' TE 6cyl Cortina,'90' TX3 Turbo 4WD Laser, '89' Honda 250CBR RR, '79' ZJ Fairlaine 351c, '69' XW Ute worked 250 pre-crossflow, '96' EF Gli, EA and EBII wagons.
Current rides, '02' BA XT work ute, '96' EF Gli-AU head and cam, king springs, Custom Bodykit 2.5"+ Extractors (and its even got cruise control).
ado351c is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2012, 11:13 AM   #12
DJR-351
I am Groot
DJR-351's Avatar
If all four wheels are the same then this is what i can't figure out, you should be able to rotate your rims without having to worry about "special" front only wheel nuts....
Sounds to me like someone has been dicking around with the car sometime in it's past. Take it down to your nearest wheel and tyre joint, if they are good enough they should be able to put you on the right track.....
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2012, 10:30 PM   #13
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Different manufacturer of the rims? Jelly beans were made by 2 or 3 different companies, therefore they would have a different thickness centre of the rim. (They varied slightly in looks)
Do you have different width rims, front to rear? Might explain a few things too..
Providing you have wheel nuts like JIMSTONE posted up, they are fine to fit. They don't have to have the stud poking out....Just the right sort of wheel nut...
Oh and when you put the wheel nut on, make sure they do up tight, and don't have a gap between the washer and rim face, otherwise you may have to put an extra washer on the ones that are loose (as ADO351C mentioned)
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 14-10-2012, 12:11 AM   #14
dave351cid
playing in my big shed
dave351cid's Avatar
could possibly have had longer wheel studs fitted to the rear axles.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2012, 12:20 AM   #15
JimStone
...rears fit fine however the front studs barely make it past the lip...
Make sure the centre bore diameter of the front rims is large enough to sleeve over the raised boss in the centre of your front hubs (ford 70.6mm)
Just incase they have been fitted to a Toyota at some stage check to make sure someone hasn't left some hub adapter rings in place too (Toyota 67.2mm)
Old 14-10-2012, 08:02 AM   #16
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
EF/EL have the longest wheel studs, out of all the Falcons etc made by ford
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2012, 09:15 AM   #17
jpd80
jpd80's Avatar
Be careful as mentioned earlier there was a change in front hub size from XB to XC,
some early mag designs have the early smaller hub centres and don't quite seat home on the spiggot.
If this is the problem, putting longer studs on could be very dangerous....
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2012, 04:31 PM   #18
snowcone
The Jellybeans I have require a straight mag wheel nut and washer, not a tapered nut at all. You shouldn't need longer studs if you have the correct nut for those wheels.
snowcone is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2012, 06:28 PM   #19
my67xr
my67xr's Avatar
they arent Valiant alloy jelly beans by any chance?
they use a tapered style wheel nut, that fits inside the alloy rim too.
can you post up some pictures of the rims you are trying to fit?
67 XR Fairmont
Old 15-10-2012, 06:39 PM   #20
Middleout
All sorted! Used some long shank wheel nuts (after I finally tracked some down)
Old 15-10-2012, 06:41 PM   #21
Kieron
If memory serves, the change was actually made part way thru the XB therefore a ZH should only have large hubs?
It's an extremely important to get this right though. Could be that the rear diff was replace with an earlier small center one and the OP's jellys are small center.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2012, 07:07 PM   #22
Middleout
it's all sorted, i just swapped them - i had taken 2 of the wrong ones from mu pal when i bought them. 2 off a ford & 2 off a valiant.
Thanks for all the help and input guys, i really appreciate it.
