I have a ticking noise coming from the rear right of my 04RWD 4spd terry.
Sounds like a credit card/cable tie on bike spokes. Only does it whilst driving, gets faster with vehicle speed, but seems to be related to engine RPM, ie at the same speed it ticks faster in 3rd than 4th. I'm hoping it's not, but seems to be transmission related, anyone got any ideas? My mechanic hasn't any ideas, we originally thought rocks in tyres. I can only hear it with my head between my legs in the rear passenger seat, wife can always hear it. Any ideas for a man going crazy? |
Sorry, it was too hard to refuse. If it were road speed I'd look at the cvs, seen problems on lowered territories. Could be a grommet missing so the noise is transmitting from elsewhere.
Black Mamba Racing Components 4B Fabrication & Performance Tuning www. 4bfabrications.com.au |
Movement in the brake pad , you most likely have a pad that is a bit smaller or a caliper that its groove is a little larger and it moves making a tick with the revoultion of the wheels . Had it with 2 of my cars 1 ford one another make , both fixed by going to a after market pad
Verrrry uncomfortable way to hear a sound I must say. It is amazing though where sounds can only be heard, or where they "seem" to come from. That sound you describe sounds like an interference from a faulty capacitor, in the vehicle somewhere, ticking in the radio. Is you radio on when you hear this sound. I've heard this in my EF. I remember it being a capacitor but can't remember where. (Can't find the repair report neither, after 12 years
![]() Your radio does not have to be turned up neither. Just as long as it's on or off.
![]() Last edited by GCRXR6; 19-03-2012 at 11:13 PM. Reason: spelling typo |
#5 | |||
![]() Join Date: Oct 2006
Rear passenger seat - that's above the fuel pump.
If it is engine speed related and NOT road speed related, I'd start there. Maybe it's normal. |
One out of left field, but I had something similar happen to me. Do you have mud-flaps on the rear wheels? I had a loose/misplaced one on an EF Falcon which would rub on the tyre at slow to moderate speeds (though the sound would disappear at a higher speed), producing an alarming sound.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
Possibly ABS ring touching on the sensor?
#9 | ||||
Life begins at 40
![]() Join Date: Jan 2005
Location: Melbourne. Socialist capital of Victoriastan.
I hope you haven’t upset any Syrians around your neighbourhood? Also, could you please post a pic of you being driven around with your head between your legs, I’d like to blackmail you later with it. ![]()
Justice is what you get when you run out of money.
Another one a little out of left field...
The little weights used to balance tyres on the inside of your rim hitting the brake calliper?
Cheers, Sam. |
#11 | |||
thanks for the ideas a hundred an one things to check now. rear pads have been recently been changed, what would be best way to try and find a click there, swap them left to right and see if the sound follows? Last edited by lamborghinifan; 20-03-2012 at 08:04 PM. |
#12 | |||
#13 | |||
#14 | |||
#15 | |||
Have we decided whether it is road speed of engine speed? Is it the same speed in different gears? Does the drivetrain have to be under load, does it alter relative to load? Joel
#16 | |||
What happened in our Peugeot is that the tyre places stacked those sticky weights on top of each other and when I had the front brakes pads replaced, the calipers were a little wider due to the thicker pads and the wheel weights would catch the caliper on their way around. Even if you jack the car up and just spin the wheels around, if it's that, you'd hear them hit without having to take the wheel off.
Cheers, Sam. |
#17 | |||
![]() sounds like it would be engine or gearbox or electrical rather than wheels, etc.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
