Old 03-02-2012, 10:31 PM   #1
kyro_02
V8 wannaabeee
kyro_02's Avatar
Default do I tell vicroads about gearbox conversion
So, I put in another motor and converted from auto to manual, do I tell vicroads over the phone, or do I have to go in and show them it?
I think they're closed tomorrow, so maybe some insight from here instead
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2012, 10:40 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: do I tell vicroads about gearbox conversion
I know in Nsw you need an inspection for engine swaps, called a 'change of details' inspection. I'm sure you will need to do similar. As for transmission, can't help there sorry!
Old 03-02-2012, 11:58 PM   #3
KRL-94
depends really. you can get away with a few things. if you put the same engine in, all you pretty much did was convert it from auto to man. IE 4L auto i your ef, and you put in another 4L with a man instead.
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time.
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
http://www.fordforums.com.au/showthread.php?t=11447916
KRL-94 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2012, 12:01 AM   #4
kyro_02
V8 wannaabeee
kyro_02's Avatar
nah,
old motor & auto box out
new motor as well as new box in, same type of engine as previous, just different engine number
Old 04-02-2012, 12:02 AM   #5
ebxr8240
Performance moderator
ebxr8240's Avatar
If there's no mods to make it work ??
If it was fitted to same model as std ??
Don't worry.. Much the same as fitting an LSD...
Daily driver GTE FG..
Old 04-02-2012, 12:05 AM   #6
KRL-94
well if you didnt de-register it you should be ok for a few months atleast. if you do get pulled up just tell them you only finished it the day before and that your getting the legal stuff (technical term) done that day. otherwise you pretty much have to give them the details, so you might as well just do it all and save the hassle down the track.
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
Old 04-02-2012, 11:38 PM   #7
ZcAmbo
If you notify them you will have to take the car down there for them to inspect the new engine number and issue you with a new rego label with the new number on it they wont bother with the gear box conversion
ZcAmbo is offline   Reply With Quote Multi-Quote with this Post
