02-12-2011, 01:58 PM | #1 | ||
Hey all,
I'm getting a quote to do a manual conversion on my AU2 XR6. A very reputable mechanic is telling me that I do not need an ecu from a manual falcon - my current ecu (auto) will do. He just needs to do a bit of reprogramming. This is strange to me, from what I have seen so far on this forum most people recommend sourcing an ecu from a manual car when swapping out trannies? I've even heard that I should make sure it's from a vct manual car if my car is vct - which it is.. So do I need a manual ecu or is this guy hoping to score a bit more cash by having me pay for a re-flash of the current auto ecu by him? Not sure which way to go at this stage.. |
02-12-2011, 02:42 PM | #2 | |||
Walking with God
Personally, that would be a pain. I'd say the flash job wasn't so flash! My car had the manual computer put in, which after programming to the car/bcm hasn't given me a hint of trouble. Others here have had their auto ecu flashed with no dramas. Up to you really. I guess if the bloke was known as having lots of experience and he can do it quickly without the need for the car to go to Ford, then perhaps go with that. IIRC the flash tune costs around the $500 mark. All the best with it. GK
02-12-2011, 02:45 PM | #3 | |||
reflashes are nice but it will be drivable without |
02-12-2011, 05:15 PM | #4 | ||
Ok thank you. Sounds like either way is a go. This fella is well renowned here on these forums so I'll go with his suggestions.
02-12-2011, 07:06 PM | #5 | ||
Critical Thinker
I too will be in your position inventiv.
Im gonna do a manual conversion probably in the new year. I was told a rejig with a flash tuner will be required if you have one to tell the ecu the trans is manual not auto. No need to rip your current ecu out. Just reflash it.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
03-12-2011, 02:38 AM | #6 | ||
Bugger!
+1 for the resistor trick. Reflashing the computer will do very little unless you're getting a custom tune as well; otherwise you're handing over a lot of money for nothing.
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
03-12-2011, 02:42 AM | #7 | |||
Walking with God
The guy who did my conversion thought all would be okay but the car idled too high and the thermo fans were on all the time. I then needed a reflash or manual ecu. I chose the new ecu route. The guy who did my conversion thought that AUs were exactly the same setup as EF/EL! GK
03-12-2011, 02:49 AM | #8 | ||
Bugger!
Done it before on both with no issue. The switches on the box are the same; which is why AU boxes can be retrofitted into earlier models. Dunno what went wrong with yours?
Although TBH it's been a while and can't remember everything, AU manuals are like rocking horse **** so you don't get to do very many!
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 Last edited by mongrelEF; 03-12-2011 at 02:55 AM. |
03-12-2011, 04:01 PM | #9 | ||
dont get any sort of programming or tune done, i did three simple wiring things when i did the conversion in my au, which is a series 2, too.
use a multimeter, and remove the large round clip on the auto, test every combination of terminals until you see one reading that is hugely bigger than the rest, imitate which clips these are on the clip, and put in a 1.5kohm resistor. then you will have a 2 pin plug, drop this and dont touch it. then you will have lastly a 4 pin plug, this is for the reverse lights, and starter lockout, when you figure out which ones do the starter lockout (easy with a test light) bridge those, as for the other two, just connect them to the reverse switch on the gearbox. if all of that has been done properly, (and yes it literally is that simple) your car will start up exactly the same as it did, idle the same as it used to, etc, no funny lights on dash, nothing. the only thing i had, was "ECON" is up on the dash, and thats not a problem, thats just funny! i did this about a month or so ago...havent had a single problem! the ecu just thinks your in nuetral 24/7, and the resistor is to stop the fans from running all the time. the only other remaining thing electrically related is the speedo, i removed the one from my auto, and put that one into the manual box. also works perfectly. did i mention cruise control still works? in any gear? hehe |
04-12-2011, 12:31 PM | #10 | ||
Critical Thinker
Thanks for the top tips Sterling. This is priceless information for my conversion.
05-12-2011, 09:17 AM | #11 | ||
no worries!! good luck guys
06-12-2011, 01:09 AM | #12 | ||
Bugger!
Just to nitpick:
1/4watt, 1.5 Kohm resistor The wiring diagrams in the Tech section will give you the wire colours you need.
06-12-2011, 01:42 AM | #13 | ||
anything other than a manual ECU is a compromise it will work but it won't be perfect. you are better off doing a proper job first off
[SIGPIC][/SIGPIC]
06-12-2011, 11:01 AM | #14 | ||
Critical Thinker
I have both. i got the xcal 3 so i can get that setup for manual. i also have an au manual ecu spare to use if worse comes to worse.
07-12-2011, 08:45 PM | #15 | ||
if anyones after a 5 spd conversion i'm selling my old girl ,here's a link to my forsale thread.
http://www.fordforums.com.au/showthread.php?t=11350759 i don't mean to spam or whatever it is ,but its cheap and comes with a lot of other goodies
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
08-12-2011, 03:06 PM | #16 | ||
Critical Thinker
That's bloody tempting to buy FS5.
I think you would make more money parting out the whole car and all of its good bits, them dumping the shell at a wrecker.
