16-10-2011, 04:03 PM | #1 | ||
Hi Guy's,
When I start the engine and start driving up the road there is a clunk that comes from the front, my other LT TDCi did it and so does my new LV. A couple of times now when taking off instead of a solid clunk as normal it sounds like something it rubbing the turbo veins. When it is warm it is OK but when it is cold or has cooled off for a couple of hours it might do it. Does anyone else have this happen? I am thinking I might need to call Ford, it is just a weird problem. My thoughts are that the clunk is a stall system for the Turbo until oil pressure is well and truly up, once going it all works fine. Noel
1400 GTR Goes like it has a Kwaka up its butt |
16-10-2011, 10:52 PM | #2 | ||
is that the clunk that happens once when your speeds hits 20KM/H?
if so, that's the ABS/ESP sensor of sorts kicking in. it happens on my Petrol focus and when the noise wasn't a solid clunk as you describe the ABS sensor/tone wheel was damaged took a few visits to the dealer to get it sorted but in the end they replaced the entire hub assembly hope this helps |
17-10-2011, 06:59 PM | #3 | |||
It would make sense to be an ABS thing as you mentioned, when driving off on a slope I am probably on the brakes and it is on a curve so it could be what you have mentioned. I will pay a bit more attention next time to see if I am on the brakes or not as this could make it worse and be the noise I am hearing. Knowing me I am probably being paranoid about noises, I am usually OK when I know what the noise is. I hadn't thought of the ABS. Noel
17-10-2011, 07:16 PM | #4 | ||
i know in the XR5's there's a clunk at about 20km/h which is the reverse gear lockout. but they're manual cars and you say it's happening in an auto??
Ex-ride: 2010 MB Mondeo - Panther Black - Just a little bit modified New ride: 2010 LV Focus XR5 - Moondust Silver - More mods than you can poke a stick at |
17-10-2011, 08:31 PM | #5 | ||
on or off brakes makes no difference to me happens once i hit 20KM/H for the first time until I re-start the car
yes it's a subtle but noticeable noise |
17-10-2011, 09:36 PM | #6 | |||
18-10-2011, 08:14 PM | #7 | ||
It seems to have been the ABS, I am used to the VR and VS commodore where you feel the Brake Peddle pulse, then you know it has initialized. I tried it today, running off down the slope off the brakes and it was quite, just the normal clunk. I am relieved it is not a turbo problem, they can be costly.
Thanks for all your input guy's
18-10-2011, 09:02 PM | #8 | ||
good to hear
well do still keep an ear out for it. if it doesn't sound right something could be damaged the first couple of times it happened to me i didn't do anything about it and eventually it worsens to the point where a warning light appears the third and final time it started happening i booked it into the dealer fairly soon after and they were able to see it deteriorate and resolve the issue |
