Old 04-10-2011, 10:23 PM   #1
chooktinute
Default Hooking up A/C on a AUI Falcon ute
Hi,
My AUI Ute didn't come with A/C and i was wondering if it is too much trouble to hook up the full A/C system onto it. Could i just find an au being wrecked and unbolt everything and bolt it on my ute?? And is the wiring already there in the wiring loom?
chooktinute is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2011, 11:32 PM   #2
Beer Baron
Default Re: Hooking up A/C on a AUI Falcon ute
I don't know about the wiring but its definitely a dash out job to run ac lines.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2011, 12:11 AM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Hmm, wasn't aware A/C was optional anymore, should have been factory standard. Are there two silver pipes coming through the firewall on the passenger side of the engine bay? if not, as above - you'll need to pull the dash out and change the heater box. Wiring should be there.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2011, 08:19 AM   #4
Rambunctious
It's certainly a big job for the home mechanic, not only the dash stuff but you also need the hoses, front pully and belt, compressor, condensor, bracketing etc, and the dryer will need to be new, there is a filter in the line which will need renewing/cleaning, then you need to pay someone to evacuate the system and regass, all the time hoping the compressor seals are good and you are not going to lose all the gas straight up.
If you get it from another car you will need every bolt, nut, screw, piece of duct, probably fan and wiring etc etc , and you will need to pull it out yourself after taking photos so you know how it goes back in.
I did an install myself on a Holden Tonner in early 90s and the cost with a new compressor then was over $1000 with me doing all the work.
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2011, 12:05 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yeah aircon was an option on the utes
imagine driving a manual, no aircon, wind up windows AU ute
that'd be just plain strange
Old 05-10-2011, 09:28 PM   #6
chooktinute
This is exactly what i drive.....
Well it seems like a mammoth effort really may not worry about it!
Old 05-10-2011, 09:44 PM   #7
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Honestly, it's not hard at all....
Remove dash = 30 mins
Remove intake piping (4x10mm bolts, and 2x P2 screws) = 5 mins
Remove old heaterbox = 15 mins
Install new heaterbox = ^^^
Install new center "ICC" = 10 mins
Remove front bar, install AC condensor/AC Lines, install front bar = Give 1 hour to do that entire job
Remove thermo fans (2x10mm bolts), remove drive belt and AC idler pulley = 20 mins
Install AC pump, drive belt and thermo fans = 20 mins
Bolt up AC lines (if not already done) = 5 mins
Install intake = 5 mins
It isn't a real big job... I've done a full dash, airbox, pump and lines swap before and had it done in less than 2 hours.....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 12:31 AM   #8
mongrelEF
Bugger!
mongrelEF's Avatar
True, though if you're not familiar with what you're doing, that time can blow out fast
Huh. Well, that's my new thing learnt for today....going back to sleep now :
Old 06-10-2011, 12:43 AM   #9
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
Surprisingly at some dealers a/c is still an option in FG and ranger utes.
XARATE is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 04:46 PM   #10
chooktinute
Yeah thats pretty good thats mostly the easy stuff all the 'unbolt this' and the 'bolt this in its place'. All the wiring was my main concern.. weather or not the wires were tucked away in the wiring loom ready to plug straight in
