Hi All
I want to get a GPS to mount in the tissue box cavity on my FG but I need one with a front facing on/off button. I like the Tomtoms but the switch is on the rear. Can they be hard wired to auto start? Has anyone seen one preferably with multi media capabilities too? cheers and thanks Geoff |
Stock Boss
I think most auto start when they are plugged into a power supply
03 BA XR8 Blueprint | Manual | Leather | Premium sound | Sunroof | Shockworks coilovers | TrueTrac + 3.73 Diff Gears
Oops did not know that, thanks
Chairman & Administrator
That is correct - I wired mine to a permanent supply (they are 5V so you have to retain the little power pack) by putting an accessory power socket under the dash and taking the power feed from an ignition on fed circuit.
Works fine - the only downside is that the thing will be useless when not powered after it's been used like that for awhile. Cheers Russ
Observatio Facta Rotae
3..2..1..
wont be the bigger issue be mounting it so the sensor is still able to see the sky?
Garmin work well with the auto power on from acc power. Tomtom do not.
I have no idea about any of the others. |
#7 | |||
Reaching for 200...
Tuddy's XR6 04' BA XR6 - Blueprint - 6 Speed with Rip Shift - HD Clutch 2.5"/BFGT Exhaust System with Quad Tips - 4490's Extractors 19" ROH Flares - 20% Underdrives - Interior Colour Coded - Sunroof - BOSS Bonnet Stage 2 Crow Cam's - Crow Cam's Valve Springs - BPR Airbox M86 LSD Diff with 4.1s - Upgraded Brakes with Slotted DBA 4000's Leather Interior - Rear Power Windows Projects Underway: Sound System |
#8 | |||
#9 | |||
3..2..1..
#10 | |||
#11 | ||||
BOSS Pilot
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
one thing you'll want to keep in mind is making it so its not too difficult to remove. need to update those things every so often
1977 MkII Escort Ghia. 2006 MY07 Subaru Liberty GT Spec B wagon. my photo blog; http://www.jamesruff.net |
