Old 23-07-2011, 09:05 PM   #1
malazn mafia
Boss 335
malazn mafia's Avatar
Default Changing normally closed switch to normally open
Is there some way to change a normally closed switch to operate as a normally open switch. The only way I can see is with a relay and power source. I need to do this to get my door ajar sensors to work. BA/BF doors work on switch closed = door open, while FG BEM works on switch open = door open.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2011, 11:35 PM   #2
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Default Re: Changing normally closed switch to normally open
Not familiar with the door switches. But am familiar with electric circuits (HV substation protection designer).
* Can you check the door switch and see if there is 3 terminals? ie both a NO & NC with a common terminal?
* Can you buy another door switch which will mount correctly?
If you are unable to rewire / change out the door switches to suit what you require. Bearing in mind there are many limit switches available. Be it Ebay or robot (just google it!!) supplies etc. Then setting up a circuit to as you suggest with a relay and power source is the only way to go. Just try to get one which is okay with the load / burden (most likely not much of a problem at all) to provide the circuit to the FG BEM.
Give me a PM if required! Good luck!
PS Go Webber
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2011, 11:36 PM   #3
RiTz
RiTz's Avatar
I'm no help to you... I just read that 5 times and I'm still goin.. Wha?? Lol
Maybe I need to go to bed 
_____________________________________________
Jo
RiTz is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2011, 12:35 AM   #4
malazn mafia
Boss 335
Thanks guys. I will need to dismantle the whole lock assembly in the BA door to see if there is a third pin. Or maybe an e-series door ajar switch retrofit might do the job.
Old 24-07-2011, 01:42 AM   #5
Benjamin Smith
Benjamin Smith's Avatar
i think the easier option is to call FTG and seen if you can get some door relay's off an FG, but if there is and auto sparky or even a normal sparky they may be able to tell ya how to do it. but i think new relay switch would be easier
Benjamin Smith is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2011, 10:50 AM   #6
malazn mafia
Boss 335
FG door lock assembly is all-in-one as well, and it doesn't fit into BA door without a lot of modification
Old 24-07-2011, 11:12 AM   #7
pcman
you can use a 5 pin changeover relay to convert it
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2011, 01:11 PM   #8
Is this for a burglar alarm? If not tell us why and there may be another solution.
Old 24-07-2011, 01:14 PM   #9
LUXO_8
windsor user
tipping he's fitted an FG cluster and trying to get door adjar sensors to work
Old 24-07-2011, 02:13 PM   #10
malazn mafia
Boss 335
This requires a power source right? Is there a constant power source in a BA door loom
Old 24-07-2011, 02:15 PM   #11
malazn mafia
Boss 335
No, my BA is electrically an FG. Motor/Box/Dash/cluster/Body looms are all FG. But the problem is I still have BA door actuator/lock assemblies and FG ones don't fit easily. The BA door actuator/lock assembly ajar sensor works on door shut, circuit open, while the FG door actuator/lock assembly works on door shut, circuit closed.
Old 24-07-2011, 03:02 PM   #12
Perhaps swap them for some burglar alarm pin switches that are normally open
eg http://www.altronics.com.au/index.asp?area=prod&grp=279
or http://www.jaycar.com.au/productView...s&form=KEYWORD
Old 24-07-2011, 06:11 PM   #13
malazn mafia
Boss 335
Hmm thanks for that. I think E-series falcons had this switch fitted as the door ajar sensor.
