Peter Car
To all the people saying 7 and 8 speed autos are a dumb idea, here's a 9 speed ZF for you.
![]() http://www.goauto.com.au/mellor/mell...2578AE00154189 |
Just slidin'
Thats AWESOME!!
MD Mondeo - For the family
NP Pajero - For the adventure |
isn't nine speed getting a bit too much??? I remember the days of the two speed slush box!!!!
CSGhia |
half way now to heavy haulage truck gearbox's.. lol
XD Sundowner
sounds very grand turismo , can see a slide on the touch screen with infinately variable shift ...will be very interesting .
something old something blue |
www.sctflashtuning.com
i hope we dont get them here , it was bad enough reverse engineering the 6 speed to calibrate
Australia's No1 Ford Enhancement Specialist 103 Northgate Drive Thomastown VIC 3074 Phone: 03 9464 5100 Fax: 03 9464 5166 |
#7 | |||
Sling Shot
It says with the 9sp Auto the car will be sitting at 1900rpm at 120km/h. My XR6 Turbo already does that with only the 6sp auto???
They should just call it CVT, as it may as well be.
Seems pointless to spend so much money on R&D for xxspeed gearboxes, when there must be better ways to gain economy, like WEIGHT !!!!
Fordless..... ![]() |
can you imagine a manual 9 speed, now that would have you busy.
#11 | |||
I was correct - AGAIN
![]() It would be nice to have more gears. The ZF 6 speed made the auto Falcon go from sluggish to spritely. |
#12 | ||||
You dig, we stick!
"....You don't put the car through engineering" - Rod Barrett. |
#13 | ||
Right out sideways
It will be great, if you are having a race, you can now change up as many gears as the guys in Fast & Furious !
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#14 | ||
Lukeyson
![]() Join Date: Mar 2005
Well, Top Gear will be able to do a story on this.
But what are 'Fifth Gear' going to do? Just like that old Falcon Ute ad - 'Must have been stuck in 3rd'..... how fast can you go using a 9 speed tranny when stuck in 5th? ![]() Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
#15 | ||
Just get CVT's working properly...
We test drove a Suzuki Kizashi Sport AWD before buying the G6E, and apart from a bit of a lack of power (turbo coming later this year apparently), it was pretty damn good. When being driven in "automatic" mode the shifts were seamless and in "manual" sport mode, the shifts between "gears" were pretty much instant. A tougher version of a box like that in a Falcon would give the perfect ratio for any situation. Not really sure why they are continuing to stuff more and more actual gears inside an automatic... ![]() |
#16 | ||
http://appsprod01.zf.com/zf.productD...P_en_2007s.pdf
ZF 8 Speed - Couldn't help notice its rated up to 700 nm torque, very nice. |
#17 | ||
Pity the fool
A 9 speed transmission: the answer to the question nobody asked.
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#18 | |||
Peter Car
![]() Not many people like CVT's, they way they work makes people think it has a slipping clutch. Some people claim having so many speeds is stupid as it will keep needing to change gears all the time, but if the shifts are imperceptable as they say, and it has the ability to skip more than 1 gear at a time I don't see the problem. Its all about fuel economy and reduced emissions these days, its easier and cheaper to replace and auto with one with more gears than it is to switch to lightweight materials such as carbonfibre etc. No need to crash test either, which would be required for light weight panels. |
#19 | ||
Even if they continue skipping only 1 gear at a time, going 2-4-6-8-9 will have it operate as a conventional 5 speed. The current 6 speeder already takes off from 2nd so that aspect is a non-issue.
#20 | ||
The question i ask is do we really need it???
I dont see the point after a 6 speed in both manual and auto, plus the rebuild and service cost is abit rich................
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc |
#21 | ||
Lukeyson
James May argues we don't need vibrating 5-blade shaving razors either. if the 5th blade gets the closest shave, why can't you just get only the 5th blade and sod off all the rest?
I agree with the CVT comment. I can't stand them - and they are setup now to have set points in them anyway. Lukeyson
#22 | ||
I am Groot
![]() Join Date: Dec 2007
Nothing more than an expensive gimmick for the braggart's...
Just like the 3,5,10,22,33 speed pushbikes..... ![]()
.. ![]() ![]() ![]() ![]() "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
#23 | ||
"It says with the 9sp Auto the car will be sitting at 1900rpm at 120km/h"
It'll be worn out already by the time it hits 9th lol...FFS! |
