Falcon Unbelievable
What diffrences are there between the Green Dedicated gas motors and the duel fuel set ups?
Which one gives more economy? Which one gives more power? Cheers |
#2 | |||
Walking with God
GK
#3 | |||
the au did not come out in a turbo AFAIK and all falcon I6 engines have gas suitable valve seats. a search of the parts database reveals that even the cam is the same. the engine itself is the same just the bits that bolt onto the inlet side are different and it has a green rocker cover. ask any mechanic and the will tell you that as LPG burns cleaner you get less oil contamination enhancing engine life so there is no need to "beef the engine up"
#5 | |||
Sly like a G6
When I got my gas put on I asked about valve saver, having previously put LPG with Flashlube on the Courier. The installer said I'd be wasting my money getting a valve lube system for the Falc due to the quality of metal in the valves & seats. Different story if I had a Commodore however... he converted & serviced a fleet of 45 taxis so should have had a bit of an idea.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
#6 | |||
Sly like a G6
#7 | |||
Only B-series petrol and EGAS engines were different. Also as mentioned.
Falcon Unbelievable
Thanks guys for the help! Im just looking into purchusing a egas AU2 wagon and wanted to know a couple of things!
Cheers! |
![]() Join Date: Jan 2005
While on the subject of egas etc, has anyone ever seen or heard of an egas being converted to dual fuel by adding in the petrol system? Would be an ironic conversion, I reckon.
In the Forced 'lane
AU Egas have different valves than standard. Bottom ends are the same.
XE S-Pack 4 Runner XH11 Longreach |
#11 | |||
Resident Nyctophobic!!
Orbits secret to life: Eat less, move more! |
FTG just got an EGAS AUII ute in ... and parts are cheap from it ... best to speak to Darren if you want anything on the LPG side of things off this ute.
#13 | |||
Sly like a G6
#14 | ||
Nah ... same setup ... just a one-piece item.
It's more an oval than a circle as well. I have no pics of it though.
#15 | ||
interesting thread, i thought i`d do some thread mining
#16 | ||
Weird. An LPG-integrated throttle body shouldn't cost more than $200 in parts. In terms of installation, it's a simple bolt off, bolt on job.
As for the B-series, the BA E-gas engine has a higher compression ratio than the petrol engine, but with the BF, the petrol engine was upgraded with the same high compression ratio to bring the power up from 182kW to 190kW. The net result is no real-world advantage to the green motor. The only difference therefore is the stronger connecting rods, only installed due to the risk of backfire from the mixer-style LPG system.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
