Old 27-02-2011, 08:18 AM   #1
DaveTE
Back in black
DaveTE's Avatar
Red face Roof lining
A question about the roof lining on my XR8. A small area of the material has come away from the backing(flapping in the wind) and i was wondering what is the best way to fix it back in position. It's on an edge so I can get underneath it to put some type of glue or the likes. Which is best for doing the job properly and not leaving marks/stains.
Thanks in advance.
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 09:09 AM   #2
SSD-85
3M Super 74 Contact Adhesive. Works perfectly.
Just make sure that you let it go off for a little bit first, and dont use too much as then you will get stains coming through.
Youre probably already aware of this, but its only a temporary fix, once your lining starts to come away in one spot, its on its way out and needs replacing at some point in the near future.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 09:42 AM   #3
kenz
BOSS Pilot
kenz's Avatar
Ive got some 'selleys kwik grip' from bunnings and used on mine. I think they had the 3m stuff there but the kwik grip sounded better. Had a section at the front come away about 3months ago and since spraying it back together it hasn't moved once
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 09:46 AM   #4
SSD-85
I bought qwik grip from bunnings once because I ran out of 3M. I found it to be damn useless. Being a trimmer, I need to pull my finger out and get a proper compressor setup.
Old 27-02-2011, 09:53 AM   #5
kenz
BOSS Pilot
kenz's Avatar
fair enough. It seems to have worked good for me. There is a 3rd brand I used once I think it was from an auto store and I couldn't even get the lining to restick at all. Not sure what the name of it was though
Black BAII XR8 Ute
Old 27-02-2011, 09:56 AM   #6
SSD-85
Yeah, it also doesnt help when your trying to stick it to an already deteriorating surface. So to the OP, make sure you clean as much of the loose old foam off as you can.
Old 27-02-2011, 12:09 PM   #7
FGII-XR6
FGII-XR6's Avatar
once it starts to come away it will keep deteriorating for a couple of hundred you can get it recovered as good as new
[SIGPIC][/SIGPIC]
Rides:
Old 27-02-2011, 01:43 PM   #8
Beer Baron
Cost me $130 to get mine redone after i attempted to do it myself.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 04:16 PM   #9
Nutcase
Beer Barron, where did you get yours done mate? I'm not too far from Darra.
Nutcase is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 04:22 PM   #10
GK
Walking with God
GK's Avatar
I've also used the small spray can of Kwik Grip to good effect recently.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 27-02-2011, 08:37 PM   #11
DaveTE
Back in black
DaveTE's Avatar
Wink
Thanks fellas once more. I'll give the qik fix ago. If or when it starts to come away again I'll get it done properly.
______________
_.__ /________...\
_.._(___\\___//___)
Old 01-03-2011, 11:48 PM   #12
ronwest
All Bran = Regular Member
I used No More Nails (it was all I had) a couple of years ago. Still working
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2011, 12:24 PM   #13
Swedishmoose
Hi there....
mine came of on the driver side in the corner of the rear window..
I used like a UHU stick..but just a tiny tiny bit...applied it with a finger pulled the fabric back and sticked it to the hard shell..after that I massaged the fabric with a soft sponge...it worked well...
It sounds clumsy and unprofessional but that was the best temporary solution until I get the proper spray glue...you can't see a difference.
All guys who have fixed the roof lining like that (with 3M etc.)....
how big is the likelihood that the spray glue soaks through the fabric so that you can see it...
Is that 3M like a dry spray glue with a fine mist?
Oh...and if you really have to renew the roof lining....can trimmers match the color scheme ?
I guess the standard color of the roof lining is a light grey/beige tone....are there exact color replacements available?
Thanks guys...
cheers
The Moose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2011, 01:17 PM   #14
ronwest
Maybe...
A few years ago, my daughter had the roof lining replaced in her commodore and even though the trimmer reckoned he had an exact match it turned out to be a couple of shades lighter.
If I were getting it done, I'd get a sample of the new lining and match it, in situ.
Either that or take a piece of your old lining in for matching.
Old 02-03-2011, 03:46 PM   #15
Beer Baron
Moorooka auto trim. Good job on the trim but they stole my change and a cd from memory.
AU XLS.
Old 15-04-2011, 10:25 AM   #16
FORDavid
FORDavid's Avatar
Default Re: Roof lining
I just took my Fairmont wagon to Moorooka auto trim. $200 for a wagon. I paid it and they did a really good job.
My roof looked like a falling parachute it was terrible to its a major face lift to have it looking new again. Much better than the 3 staples i put it it at one point LOL.
FORDavid is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2011, 10:28 AM   #17
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah I got mine done at http://www.allcarinteriors.com.au/ in windsor
I think it was $160 for my sedan. Materials would have cost me at least half that
Old 15-04-2011, 10:42 AM   #18
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
I used a can of multi purpose spray adhesive on the wagon above the drivers door about 3 years ago and it's still holding up and before that, on a NF Fairlane for the same end result. Having said that, it did take 2 attempts on the Fairlane because I didn't clean out first. So as Scotty85 says, clean out the old dead foam before you glue it.
Bushbasher
MINE- AUII Forte
