75th anniversary
hi, would anyone know how to remove the side door moulds on an AU 2.
I need to remove one of mine on the rear because the end near the front door has lifted and bent. thanks
LZ 2016 Focus RS in shadow black |
Giddy up.
I am not completely sure but I think they are just glued on, so maybe try a heat gun/hair dryer, but be very carefull not to get the pannel/paint to hot, allway's move the gun around and don't stay in the one area.
75th anniversary
thanks, i will have a go on the weekend
#4 | |||
not here much anymore
RAM 1500
Oo---oO
when my painter swaped mine for the BA ones i think he said there were two screws from inside the door through said holes? May be wrong though. I'd pop the door trim off and have a look first to be sure before you start pulling at them...
AU2 Fairmont Ghia - Monsoon Blue, TS50 wheels -ongoing project. Successful transactions with the following members: Ride, Raised by Monkeys, TICK4D-TAS, Falcman007, 2002AU, JC. |
They're a combination of the tape and bolted on, access by removing your door trims.
Cheers Nathan |
Alternator
they are just glued on they will just pull straight off pretty easily
i havent seen any bolted/screwed on before cheers |
i know they plug into the door atleast so not sure about bolts but will deffinately be holes under them
Alternator
yeah there are definitely holes under them and the moulds have plugs or tabs or whatever you want to call them but they dont really do anything to attach them at all they are probably just there for alignment its the glue that holds them on
