Old 29-03-2011, 10:38 AM   #1
2fast4me
Default Clunk 1st to 2nd Auto
Just bought a 1999 AU Fairlane auto 6cyl, terrific car however its now developed a clunk when changing up to 2nd in the auto and occassionally another noise clunk/bang when turning a corner at low speed.
A mate said service the auto however as far as I know there are adjustments that can be made just a fluid change.
Anyone have any thoughts?
2fast4me is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2011, 12:58 PM   #2
Donny
Tickford 220kw Windsor...
Donny's Avatar
Default Re: Clunk 1st to 2nd Auto
The autos in these are sealed up, they dont even have a normal filler tube unless added by someone in the past.. Any alterations to the bands/clutches etc would require the pan off I would expect, and then you service the auto anyway.
You could have one of those electronic shift kit addons, and that may need adjusting possibly.
I would guess that the issue you have is more of a mechanical one than any electronic one tho..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue....
2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver...
Donny is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2011, 03:20 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
So when was the trans last serviced?
How many kays on the car?
Could be an S5 solenoid.
Old 29-03-2011, 08:32 PM   #4
Stav
Smile
Stav's Avatar
If your box is slipping around the corners then the fluid may be low.1st to second may indicate a high idle or s5 solenoid needs to be looked at.
Old 30-03-2011, 06:39 AM   #5
adrian k
adrian
adrian k's Avatar
you sure its not the diff clunking?
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 07:32 AM   #6
2fast4me
Thanks
Fluid is the right level and still a nice red colour so I presuming it was serviced in recent past. The car has done 301,000kms and has had an exchange tranny at sometime as there is a sticker under the bonnet.
Is this s5 solenoid internal or external?
To me the clunk is auto as I aware of diff clunk or suspension bush clunk which I have had in the past in a FG and BA.
Sometimes the clunk just isnt there and is also less noticeable in Econ mode.
Old 31-03-2011, 09:39 PM   #7
Stav
Smile
Stav's Avatar
Ironically my car clunks in auto mode and not in power. S5 solenoid is internal .The valve body needs lowering to turn the star adjusting screw clockwise .It makes the box firmer and tends to take out the clunks and sloppy shifts.
Old 01-04-2011, 06:09 PM   #8
2fast4me
Thanks Stav,
I am not confident playing around internally with the transmission.
Looks like a trip to an auto trans specialist.
Anyone know a good one around the Hurstville area?
