Old 08-09-2010, 10:28 PM   #1
adrian302
Default AU VCT lag
got a au xr6 vct and getting alot of lag when i give her a bit, and especially around corners, any ideas???
adrian302 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2010, 10:32 PM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
explain the lag mate...
does it hesitate, feel like a flat spot, changing down gears slow..etc
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2010, 10:38 PM   #3
adrian302
yea exactly lyk that
Old 08-09-2010, 11:04 PM   #4
Day-mow
rexnet
Day-mow's Avatar
serviced the car recently?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 09:19 AM   #5
Jimmyd
For starters you will need to eliminate common issues. I would recommend the following (assuming these have not been done as yet);
1. Service Auto - many find it surpirisng what a box full of fresh fluid will do for both performance and driveability
2. Check/replace Plugs/leads
3. Replace Fuel filter
4. Check O2 sensor
5. Reset ECU
Take for a drive and advise outcomes.
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 09:52 AM   #6
mik
mik's Avatar
if the battery has been reset recently i`m not 100% sure on this but i think it resets the ecu to economy mode, this is what i found on my vct xr6, it took me a while to wake up why it felt a bit less spritely even my brother commented on this when he drove it.
Old 09-09-2010, 02:50 PM   #7
sd1800
If it's around corners this would point me to Fuel Pump or Fuel Filter.
Filter is probably due to be changed anyway and the pump is only $55 off ebay.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 03:00 PM   #8
Grippy
Racing improves the breed
Grippy's Avatar
I had exactly the same problem you described when I had my old VCT engined XR6, mainly when accelerating after turning a corner. Turned out it was the fuel pump sock, quite a cheap fix
1970 Mini Cooper S Historic Group Nc Touring car
1964 Mini Cooper S Historic Group Nb Touring car
2024 Subaru Outback Touring XT
Victorian Hill Climb Championship
Grippy is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 05:12 PM   #9
SSD-85
VCTs come standard with lag
Seriously though, I agree with the idea that its a fuel delivery issue, since its the only thing to really consistently cause that in a corner.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2010, 11:56 AM   #10
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Turn your boost up, install a black bonnet, altezzas, should fly then
I wonder if my fuel sock is clogged, I've done 184k on mine and it does sometimes seems to struggle so I know what you mean. Just did a major service on it which has made it a lot smoother than it was however I sometimes find when you give it some off the lights it sort of goes... but then starts to pick up the pace quickly at around 3k, or is that just the VCT?
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2010, 09:58 PM   #11
Jimmyd
Define "you give it some off the lights it sort of goes... "
Video of my AU1.5 VCT Fairmont Ghia (traction control off) with 2.5 cat back, no other mods
http://s681.photobucket.com/albums/v...t=FILE0009.mp4
James
Old 15-09-2010, 11:51 AM   #12
grandpa_spec_F6
AFF Whore
Sorry I'll clarify my statement. Foot flat off the lights, it feels like a dead spot, it starts to move, but around the 2.5 - 3k mark it suddenly picks up performance, the exhaust note changes to a sharper more aggressive tone, and the RPM's climb quickly.
Favorite Quote:
Old 15-09-2010, 11:56 AM   #13
Jimmyd
how does it compare to the video?
Old 15-09-2010, 03:04 PM   #14
grandpa_spec_F6
AFF Whore
Currently at work, they have blocked streaming video, will let you know once I'm home
Favorite Quote:
Old 15-09-2010, 06:50 PM   #15
Day-mow
rexnet
Day-mow's Avatar
How many seconds? That vid doesn't work oh my iPhone very interested to know tho
James
Old 15-09-2010, 07:50 PM   #16
Jimmyd
Around 7.5 seconds
James
Old 15-09-2010, 08:19 PM   #17
Racecraft
they call me Tibbo
Racecraft's Avatar
if it is a BTR 4 speeder and factory diff, you have to keep the car in a sweet spot rpm wise or it wouldn't pull the skin of a rice pudding
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2010, 09:16 PM   #18
MrAUII
MrAUII's Avatar
My forte is doing the same thing again. Had it service all plugs etc and 2 months on its come back.
AUII Forte 4.0L - AUSOM3
Audio Visual Incar Entertainment
MrAUII is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2010, 08:42 AM   #19
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
At least some of that is the VCT. My Fairlane is the same, feels a bit flat till it gets to 2500rpm or so then it gets up and goes much harder.
Bushbasher
PS. Try changing your driving style a bit and see if that helps. Instead of mashing your foot to the floor, try hitting it to about 1/2 throttle then progressively feeding it to full throttle. I think you'll find the motor will respond better as it won't just dump more fuel and air into the motor than it can process at low revs, it'll scavenge better and keep the mixture a bit leaner and closer to optimum for a better burn and so should make better power. It's a "seat of the pants" thing, lol, with a bit of practice you'll get a feel for it. ( I hope that makes sense,lol)
Bushbasher
MINE- AUII Forte
Old 18-09-2010, 01:30 PM   #20
Jimmyd
Bushbasher
Bushbasher
Agreed - Driving a VCT effectively is very different to an I6 - bit like the differnce between drving a 5.0 Windsor and a 5.4 Boss.....
Old 23-09-2010, 08:10 AM   #21
Blue_Flame
Where is the fuel sock you speak of? is it in the tank?
Also at the expense of looking stupid, where is the fuel filter?
I'm only asking because I have not actually got under the car and looked for it, didn't think of it when I was under there changing the HT leads yesterday
Thanks Guys.
Just did a search, found it.
Blue_Flame is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 07:44 AM   #22
Day-mow
rexnet
Day-mow's Avatar
Fuel filter is near rear left tire
Old 26-09-2010, 09:54 AM   #23
Blue_Flame
Thanks Mate, tight sucker to undo.
Old 26-09-2010, 10:03 AM   #24
Day-mow
rexnet
Day-mow's Avatar
Yeah it's well gay. I had issues getting it to seal a few when I changed it. 3 goes got me done. Did get a face full of petty tho. Safety glasses win!
