Old 10-04-2010, 01:56 PM   #1
lance
lance
lance's Avatar
Default TC?TC cortina 2.3 litre v6 conversion?
Just wonering if anyone has converted a 2litre td cortina (called a mark 3 over here in nz) to run the 2.3 litre v6 engine out of the later model cortina. Also, what other parts can be used eg brakes, suspension, to make it handle better?
1971 XY GTHO replica electric blue 4spd black trim Sold
1984 XE Esp Fairmont Ghia 6cyl Sold
1984 Xe Fairmont Ghia 6cyl Efi Sold
1966 Xp deluxe sedan Sold
Mk2 escort sedan 1600 Sold
Mk3 cortina 2 litre Sold
1975 Xb Falcon 500 250/ column auto 94000 kms
Current
lance is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2010, 02:42 PM   #2
atec77
Plenty of 3 litre capri v6's been fitted and lots of v8 so it shouldn't be a problem , bigger brakes might not even be needed ( good idea though how do you go with warrant requirements?
Old 11-04-2010, 11:23 AM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I don't think any cars with the Cologne V6 were sold in Australia. "Standard" upgrade stuff would be the way to go. You might be able to get a set of engine mounts from the UK or Europe without costing too much.
outback_ute is offline   Reply With Quote Multi-Quote with this Post
