Hey just after a few idea's. ATM i have super low springs all round in my au. Now cause it is to low for my needs. What should i do? Put lowered heavy duty springs instead of super lows. Or get Airbags. Also i have a tow bar it would be nice to use it when i need to.
#2 | |||
![]() but seriously, is it to low cause it sags in the *** when loaded? Or just too low in general? If its just when its loaded look into a set of "poly air springs", like air bags but without the gayness! ![]()
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
Audi S3
no such thing as too low
![]() i need to go and get the SSL's reset in the rear of mine, just isnt as low as i would like, then get the front done to match! i disagree about bags being for fags but ![]() ![]() and they give you heaps of street cred! one day ill get some hah
#4 | |||
So anyone done this to there car?
Has anyone got HD springs in the back of there car? What shockers did you use?
Critical Thinker
Im using Eibach 30mm lowered springs and BOGE shockers. With 3 people in the back, the wheel arch sits about an inch from the tip of the rim itself. With no one in the back, it sits 1/4 inch above the tire.
With air bags, be prepared to pay. Its not cheap. But it also depends on the way you orientate the setup. For intance, are you looking for quick height adjustment or happy with gradual, because the cost can be dependent on the type of pump you use. Is it for rear only or for front and rear? I recommend calling up and asking them for further advice as to your application. http://www.polyair.com.au/ http://www.airbagman.com.au/lightvehicle.html#
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
Ok well im thinking im goin to just get some HD rear springs standard height and some Sport lows front. What do people think of that? Will my car sit level? Cause atm my car sits lower bout an inch at the back with super lows all round. Also should i change my shocks, I have Monroe Gas atm, do i get some comfort shocks?
Thanks |
Critical Thinker
why dont u get XR6 height springs? That way u know it will be all good all way round.
As for Monroe shocks, Id go these http://www.monroe.com.au/products/gt...echnology.html
#10 | |||
