IR84RD
got the official diagnosis on the xr8, valve spring it is, going to attempt this myself with a few mates over the next couple of weekends, i heard a rumour that if i make a fitting for my compressor that fits into spark plug socket, that the pressure should be enough to hold the valve up enough to remove and replace the springs, has anyone heard of this working or any other ideas/tricks to not have to remove heads
cheers
3rd generation Ford man 01 AUII XR8 220kw White |
All Bran = Regular Member
Yes, compressed air works.
Another way is to feed a length of cord down the plug hole, enough to cover the top of the piston when piston is btdc by an inch or so, then rotating piston to as close to tdc as possible. Cord sits up against valves preventing them from dropping. I've used both ways successfully. edit: obviously you'd leave the end of the cord hanging out of the plug hole so you can remove it when finished ;) Last edited by ronwest; 22-01-2010 at 07:45 PM. |
#3 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Thats how I did mine, we used the screw in adapter from a compression tester to fill with air .
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
IR84RD
excellent, might even start tonight, where can i get my hands on one of these compression tester parts, bloke at work was going to modify an old spark plug, but he's on holidays for another 2 weeks
Rusticating
Have you ever tried to bash the guts out of a spark plug? Difficult & dangerous in my experience.
Territory SYII RWD, BFII RTV tray |
#6 | |||
Former BTIKD
![]() Join Date: Mar 2005
I used the compressed air method on an old V12 Jag a long time ago, borrowed the air/sparkplug fitting from a mate in a workshop, so someone must make them.
Try asking your local Repco? NOT StuporCheap!
so you want one of these,
http://www.matcotools.com/Catalog/to...&page=3禁 the third pick down, sorry i don`t know where to get one locally. |
Former BTIKD
I used compressed air to do mine; I just used an Enzed fitting with a bit of hose on it. Make sure the piston is at TDC so if you lose air for some reason there is 1/2 a chance of salvaging it if the valve falls. but in doing so you have to make sure the motor will not spin, if its manual leave it in gear at TDC if its auto I usually use a socket and bar on the crank to hold it, if it even tries to move at all. Also make sure you change the valve stem seals while you are there.
#11 | |||
Do this for every cyl. never had one drop. If you do it this way, make sure if manual, put in netural and auto in park.
We salute those brave souls that enter the DARK side |
#12 | ||
IR84RD
good info lads, i was going to start this morning but it quickly got into the 40's out here, so i've postponed the start, and, i didn't realise i would have to remove so much to just get to the rocker covers, a few trips to the shop for tools maybe required through out this exercise
#13 | ||
i reckon one of these would be handy too , i always had one of those big ugly arkward buggers or made something up in the shed, http://buy1.snapon.com/catalog/item....re&dir=catalog
#14 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#15 | ||
Hmmmmm Mulberry....
HINT:
Put a socket on the retainer and give it a whack first. It loosens the collets. |
#16 | ||
IR84RD
lookin like i just don't have the time to do this myself, any guesstimates on a cost from the local mechanic, the cars done 200 *** + k's so should i probably change them all or just the busted one (s)
#17 | ||
IR84RD
so she went in this morning, waiting for the damage call, hoping its not to excessive
#18 | ||
IR84RD
official verdict is in, no. 2 cyl inlet valve spring done and dusted, everything else looks mickey mouse still, 3 to 4 hours labour beats tryin to do it myself, could just imagine all the swearing and kickin stuff around if it didn't go as i planned, good thing is i should have around 400 left to play with, any suggestions on what i could do with this coin
