Old 09-08-2009, 05:04 PM   #1
Fi.ES.TA
Fi.ES.TA's Avatar
Default Sound system
Anyone know how its possible to wire an amp into the fez?
Fi.ES.TA is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 05:11 PM   #2
Ben85
Ben85's Avatar
Dont kno how to do it personally, but it can definately be done at any audio shop, they use a converter of some sort that uses the speaker wires to connect to the deck rather than RCA's. I had it done to my WQ before i decided to change the headunit.
2006 WQ Fiesta Zetec Sea Grey
Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp.
Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction.
Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's.
Ben85 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 05:14 PM   #3
Fi.ES.TA
Fi.ES.TA's Avatar
Cool thanks for that ben appreciated.
Old 09-08-2009, 07:59 PM   #4
zbeasty
zbeasty's Avatar
As Ben said you'll need a line level converter or two if you want front and rear. If you're doing it yourself the wiring diargram on here will help make sure you get the phsaing right. You'll also need a remote turn on for the amp. You can either take a feed off an accessories line so that it turns on automatically when you turn the car on or you can use a permanent power line and put in an inline switch so you can choose to have it on or off.
zbeasty is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 11:06 PM   #5
Ben85
Ben85's Avatar
Thats it a line converter. Couldnt think of the name of it to save myself.
