Formally FairmontPom
Ok, so looking at getting the car road worthy'd soonish to put on the market again, and took it to my mechanic to get a couple of things checked out... turns out we need a new power steering rack, as it's dripping fluid and will not pass the RWC.
Been quoted the following, I would appreciate it anyone can put their 2cents worth in regarding this : $450 for reco steering rack $265 labour $50 front end alignment (recommended) $82 'power steering service' including flushing all lines, reservoir, new fluid blah blah blah $847 all up What do you knowledgeable people think ??
1998 XH Falcon V8 S Pack, white, couple of dents. Bogan project 2020 PX3 Ranger XLT 4x4, 10 speed BiTurbo, Tech Pack, Black wheel pack, HSP powered roller shutter, LED fogs, tailgate central locking and auto fold mirror upgrades. |
#2 | |||
You can't stop the signal
No way. When I did mine a year ago it was
$220 for reco rack $132 labor $33 wheel alignment $385 total That was over my side of the city though, Prestige Power Steering. But it only took half a day to do so not to bad of a wait. Make sure the rack comes with a warranty too. Mines got a 24month/40,000km warranty, and it needed to be replaced as it started to leak. Cheers
Walking with God
Last time I had one done Andy, it was about $350 installed for a reco rack, with the alignment.
They're overcharging by a large amount. Ring for another quote elsewhere. You could try where I've had both mine done. Not sure what they'd charge these days, but well worth the call I'd say. Even though it's a way from your place, getting a competitive quote would be handy. Prestige Auto Venue 45 Charles St, Coburg North, VIC, 3058 Phone Number: (03) 93542962 Cheers, GK
#4 | |||
Should of said mine was in thomastown if that helps, but it's still a fair way off from you.
Seams like you being charged double what you should be. Cheers
#5 | |||
Walking with God
Perhaps give him a go. Cheers, GK
Critical Thinker
I think I up for a similar problem. Good to know what the going rate is so when I get mine checked out Im not getting ripped off
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
Thanks George and 'Roo... glad to hear some more reasonable prices...
There's no way I'd pay the $800+, but it's interesting acting like the innocent motorist to get quotes and then laughing later on at how much they are ! Will suss out exactly what else I need to do - and also the situation on the Fords replacement, and then start the ring around. Cheers, Andy
i reckon you should get the system flush automaticly and if it was`nt done they did you a dis service imo!, an alignment is mandatory, your quote Fairmontpom does look a little high though, they have loaded a couple of hundred on the rack at the very least $150, i did reco my own rack the year before last (pain in the posterior), from Bayford`s a (Bayfords have their own dedicated power steering section(coburg) so should`nt leak after installed) reco rack was about $250.00 ....$450 seems a bit exorbitant, the $82 dollars to flush the system ...hydraulic oil ain`t cheap, beware a cheap job is not always a good job.
Critical Thinker
Well i just had my car in for a $14 28pt safety check thru pedder's just to see if they could find out what the knocking noise is coming from my front end was.
Apparently they couldnt pin point the exact cause of the issue. But they did find the following which could be contributing to the noise: Rack Mount bolts loose (they tightened for now) Possible suspect seized LHS rack end Leaking Steering rack LHD rack boot leak Sub frame bolts loose on both side. (they tightened for free) Lower ball joints are worn on both sides Rear Upper & Lower trailing arm bushes loose. They went over the car for nearly 2 hours tightening things up where they could. When I left I did notice the car wasn't making as many noises as it was and it felt tighter to drive, but the knock was still there although not as prominent. All up the fee structure to supply and fit the above work goes like this: Ball Joints - $128 Steering Rack & pinion - $440 R&R Trailing arm bushes - $490 Fitting Labour - $550 Wheel Align - $55 Workshop consumables - $10 GST - $152.10 Total - $1673 ![]() Anyone think these prices are acceptable???
lol - no
![]() The trailing arms at that price would be change over I would say Recond rec would be a lot cheaper |
#11 | |||
Critical Thinker
Im a mechanic but I dont like to get my hands dirty anymore - IT is more fun ;)
I have a mechanic friend in Trott Park who does my work, if you want details, will let you know Ball Joints are to expensive, as is the rack and pinion. I recon approx $400 for both is right). A front end Align should only be $40 = $45 and if you cant get that done in 5 hrs (@ $75 per hr = $375) then you shouldnt be working on cars. Either that or your sticking to the book times and thats why charges are like this! |
#13 | ||
Critical Thinker
Thanks Erich. Appreciate your input. Hmm Mount Compass hey? My mate lives there too. Nice spot.
Back on topic. Should my mechanic buddy fall thru, I will contact you for further info.
#14 | ||
np
I see you got that K&N Panel filter on EBAY :P PM me if ya headin up to Compass - will give ya me details ;) |
#15 | |||
Critical Thinker
re: compass, for sure. I usually go there to grab pepper steaks from the local butcher. But mym mate lives there and I visit him and his mrs at the same time.
