28-02-2009, 03:18 PM | #1 | ||
Back to N/A land
Dudes
Got a weird issue that I really can't figure out why is occuring Basically, when the car revs (usually 1/2 to full throttle) when it hits about 3000rpm it basically feels like it "pulls back" (kind of like traction control feel) and feels doughy up top, almost like its pulling out alot of timing something. This was happening last week (as well as a massive miss) however I put new leads, plugs and air filter in which has fixed all the missing, however this issue still remains (though not AS noticable) Any ideas ? BTW car is AU3 XR8.. |
28-02-2009, 05:14 PM | #2 | ||
When in doubt, GAS IT!!
It's not leaning out is it? put a bottle of injector cleaner through it and change your fuel filter and see if that makes a difference.
Bushbasher
28-02-2009, 05:28 PM | #3 | ||
Is this with < 1/4 of fuel?
28-02-2009, 05:32 PM | #4 | ||
Afterburner + skids =
Could be a breakdown in the coils as well. Are they the original coils?
Also, can you hear any pinging?
28-02-2009, 06:37 PM | #5 | |||
Turbo Falcon Fiend
Thats what I was thinking
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
28-02-2009, 06:42 PM | #6 | ||
Could also be a blocked cat
02-03-2009, 11:39 AM | #7 | ||
Tickford Equiped
Another vote for a blocked cat.
I had a similar thing with mine where first it was the fuel pump oversuppling fuel (looked like a diesel truck when driving), after that was fixed, about 2 months later i had your symptoms. I took it to my mechanic and they spent 2 days on it, got specialist equipment down from brisbane and all sorts, in the end it turned out to be a collapsed cat (obviously from the overfuelling issue). New high flow cat & a tune up & the thing went better and harder than it ever had before. A new cat (or two in your case) isnt cheap, so try replacing the fuel filter, clean the filter sock on the pump & run some injector cleaner through it to see if that clears it all up first. If that doesnt then check the cats. Also, try disconnecting the battery and letting the computer reset overnight. It may sound simple, but it has fixed many a problem with my car that I thought would have been something else. Cheers Col.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
02-03-2009, 08:14 PM | #8 | |||
02-03-2009, 09:35 PM | #9 | ||
adrian
na, my XR8 did just that and i don't have any cats. Ford cleaned the TB and reset the ECU and i put a bottle of injector cleaner thru it, and the flat spotting is all but gone now, really have to pay close attention to notice only the slightest hesitation.
months before i had already had the fuel pump changed out due to the 1/4 tank surging issue.
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
03-03-2009, 10:56 AM | #10 | |||
Tickford Equiped
03-03-2009, 02:06 PM | #11 | ||
Back to N/A land
Cheers dudes
Fuel filter is new, the issue was occuring under 1/4 tank, however I'm sure it was occuring above that level as well.. But I'll check it again to make sure (My EL XR8 suffered the 1/4 tank issue as well) I'll see if I can borrow some coils as well and see if that helps out... If it ends up looking like the cats and I'll just have to buy a couple cats and some bends and build a new exhaust rather then just replacing the cats (Exhaust system has def seen better days) |
