#32 | ||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Picture 2 will do it
#33 | |||
www.TUFFCARPARTS.com
#34 | |||
Resident AFF detailer
"According to Brendan, the factory computer supplies a lot of fuel, so increasing the airflow to match it is all they've had to do for some of their kits" So anyways.....assuming I fit my EF airbox lid to the AU.....it has a larger outlet hole (EF - 80mm; AU - 55mm).....so I need to fit some 75mm/80mm piping from airbox to TB......should I use PVC? Stainless (won't this heat up the air too much and therefore not be as good)? Silicon radiator hose?? Something else???
No longer an 'active' detailer. |
#35 | |||
#36 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
UK
#37 | |||
