we have au 3 sr wagon we change the battery and now it stalls at round about it idles ok when put in gear it playes up autobox but when i unplug the throttle sensor out it comes good
black ed lowerd king springs 16" mags pioneer sound system. ![]() |
Stroking it...
seems strange, how long ago did you change the battery?
Its normal for a car to run roughly for a few hunge k's after a ECU reset, but not sure that i have heard of it being sorted by d/c the TPS, so we might need more input here
Had: 347ci AU Then: ![]() Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
#3 | |||
Blown 5L coming
there is a procedure to follow after ECU rest that will get the car running properly before driving any where. theres a thread on it here somewhere, just havent looked for it as yet. The car needs to learn the driving style again after a reset so just leave everything plugged in (you can actually bring up trouble codes if you go unplugging things left right and center) and drive it normally, as mentioned above, it will come good in a couple hundred ks.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
Yep you should not be disconnecting the TPS, it will cause it to run at higher rpm due to a fault code being listed.
So disconnect the battery again for over an hour and then re connect it and do the re leard procedure.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
#5 | |||
Walking with God
Resetting of AU ECU http://www.fordforums.com.au/showpos...9&postcount=85 Hope that gets it sorted for you. Cheers, GK
