19-11-2008, 03:43 AM | #1 | ||
BA XR6T UTE - ANIM4L
did AU's ever come out standard with fog lights that fit into the standard AU falcons front bar?
cheers, Gonz.
. . . BA XR6T"ANIM4L" UTE UNDER CONSTRUCTION! WA Member of proUTES.com : we need more FORDS!! CHECK OUT MY OLD AU UTES!! IN HERE! CHECK OUT MY OLD FG UTE!! IN HERE!! CHECK OUT MY LATEST BA UTE!! IN HERE!! YOUTUBE POWERCRUISE VIDEO!! CLICK HERE!! YOUTUBE INCAR VIDEO!!CLICK HERE!! |
19-11-2008, 06:11 AM | #2 | ||
No they didn't, but I have seen people custom make their own.
2006 SY Territory Ghia RWD in Seduce
With 3rd row seats, Velour Trim, Alloy scuff plates, deflector, Tinted windows & BF GT Lower Snorkle www.bseries.com.au/2fishingdogs/terry 2004 BA MKI Tradesman Ute 1 tonner in Vibe Tinted windows, Alloy scuff plates. The rest is still stock as a rock www.bseries.com.au/2fishingdogs |
19-11-2008, 08:26 AM | #3 | ||
THE Fairmont Ghia 75th
while on this subject, does anyone have pics of fog lights for there au's while still having the standard au bar?
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
19-11-2008, 08:34 AM | #4 | ||
I wouldn't mind seeing some pics myself. I never understood why the EF/EL and BA/BF got fog lights that fit (rectangular) and are readily available aftermarket, but the AU didn't.
19-11-2008, 09:25 AM | #5 | ||
hmm, i didnt think so, weired ay? its the shape that makes it difficult to make, i would like it to look factory, i think ill need to look around at other makes and see if i can spot one similar in shape and retro fit it.
if any one has a good example of fog lights on AU's please post it up, i would like to see what it would look like, cheers, Gonz.
19-11-2008, 11:55 AM | #6 | ||
i have a few saved on my desktop at home so i will try post them up tonight for ya, i have been looking around a alot of other cars to find something that will fit alright
19-11-2008, 12:46 PM | #7 | ||
not here much anymore
Easiest way to do it would be to buy a light thats around 80-100mm in diameter and mount it behind the front bar so it 'fills' the brake duct hole if that makes sense. youd want one that is a rectangular shape so something a long the lines of the Hella "Comet" series would work well.
2024 F150 XLT
19-11-2008, 01:24 PM | #8 | ||
That only works if its a Series 2/3 XR front bar. The normal AU front bar is a little more tricky, with the curvy wedge shape.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
19-11-2008, 01:24 PM | #9 | |||
You can't stop the signal
Kenz effort
Mechan1k au3 chaser - Now kia chaser DVL40L - Now BFwagon
19-11-2008, 01:30 PM | #10 | ||
I'm planning on doing something very similar to AU3Chaser.
I'm also working on another fun little project to do with the XR bar.
19-11-2008, 01:35 PM | #11 | ||||
19-11-2008, 01:40 PM | #12 | ||
In a way, yes. I am making an XR style front bar that is a direct replacement for the standard bar.
19-11-2008, 01:47 PM | #13 | ||
I did a very quick crude shop of what I'm talking about.
The finnished product will obviously be without the XR style grille. It will just be the lower section, so you can swap it over with any non XR AU Bar. I stole the image from Russel, sorry mate, but it was the cleanest image I could find at the time. This one has fog lights in the brake duct holes. Just to show what could be done. I've also increased the size of the airdam/radiator area, but this was just to play around. It may help if an intercooler is used. EDIT: Please be kind :P I only had MS Paint available to me.
19-11-2008, 02:09 PM | #14 | |||
2024 F150 XLT
19-11-2008, 02:28 PM | #15 | ||
lol at the above, but yeah i like the au3 chaser idea, similar to what i want to maybe do
19-11-2008, 03:56 PM | #16 | ||
you could probably modify a set of another type of car to go where au3 chaser had his you could remove the original plastic bezel and fit something in there check out ebay http://shop.ebay.com.au/?_from=R40&_...All-Categoriestheres heaps of different shapes and sizes....
19-11-2008, 05:47 PM | #17 | ||
just a few ideas to use... until ya actually have a good look and can measure up etc its only an idea.i will have to go into a mates work and check some cars out now,lol
ford focus 05-07 holden statesman honda jazz mitsubishi lancer 08 toyota camry 02-04 toyota prado
19-11-2008, 11:59 PM | #18 | ||
ohhhh, i like the Prado ones!! ill let you know what i find, ill be looking around now too!!
Gonz.
20-11-2008, 07:24 AM | #19 | ||
The Jazz ones look fairly close
2024 F150 XLT
20-11-2008, 07:33 AM | #20 | ||
yeah i might go check out the jazz and a focus, ill take one of the little black plastic bits with me, see wat i can work out. cant be too hard...
20-11-2008, 10:06 AM | #21 | ||
The Camry ones look good too, mount them upside down in the corners of the standard bar.
20-11-2008, 10:55 AM | #22 | ||
Anyone got a pic of the front bar on the car without the plastic inserts?
Would provide a better idea as to what has a better chance of fitting. |
