09-11-2008, 07:29 PM | #1 | ||
What is the difference between the standard head unit and the premium sound one? also are they straight interchangable. can factry sub be hooked up to a non premium unit?
10-11-2008, 12:19 AM | #2 | |||
AU DIE HARD
Depends on what model you have S1 S11 S111.. Basicly premo had 6 speakers plus factory fitted sub and amp , also was a 6 stacker in dash, S11 had a cassette player as well .. a single disk player will be a straight swap with a 6 stacker.. I would guess you could hook a sub to the standard h/u if you ran RCs to amp or such ..
10-11-2008, 12:30 AM | #3 | ||
The none premium unit in S1 i don't believe even had the option for RCA outs, the premium unit in S1 had the connection for rear speaker out but it has no internal amp for it and has a 4 channel amp thats running subs and rear speakers, so it doesn't actually work in S1 that way.
But you can always just buy an aftermarket amp and run the speaker wires from back speakers into the hi level input on amp, if your going to do this just make sure the amp actually has a hi level input cause some don't. If you already have an amp that doesn't you can get an adapter.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
10-11-2008, 08:48 AM | #4 | |||
Blown 5L coming
and forget the factory 6 stacker, i have heard too many bad stories about how they crap out all the time....and the factory subs arent that great either apparently
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
10-11-2008, 01:17 PM | #5 | ||
THE Fairmont Ghia 75th
you will never use a factory stereo no matter what car you drive if your into sound quality, premo is alright for your average joe that doesnt really give 2 s**ts about musc but yeah, its always better to go with an aftermarket one, dont waste the time and effort, i had premo sound in my fairmont but soon got over how underpowered it all was and how flat the sound was, so now its got a fairly large serious system in it that im pretty happy with.still got all the premo gear incase i want to put the stezza in another car caus i aint spendin this sort of money on a stereo again.lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
10-11-2008, 02:12 PM | #6 | ||
Well some would be amazed at how good my standard premo head unit sounds running into my amps/speakers/subs, although it is lacking a bit of voltage out on rca's.
The factory in boot 6 stacker is ok, just when your cd's get stuck in it, you pull it out and bang it down while hitting eject, they soon come out and works good for another 6 months ;).
10-11-2008, 02:28 PM | #7 | ||
haha the in boot stackers are prolly better than the in dash ones but still, i had no problems with anything to do with my premo sound but i want SQ so i decided to go all out, if i wasnt serious about better quality sound i would have stuck with the premo sound as it has always done alright by me...
