20-06-2005, 10:48 AM | #1 | ||
X-Series Club Moderator
Moved house yesterday and setup my entire theatre system, all seems to be right except the subwoofer which lets off a "BUZZ" when the following instances occur....
- I turn on the subwoofer after the amplifier - I change the input selection (DVD input, CD input, TV input, etc.) - Whilst playing a DVD, it did it at commencement of the movie : - and also there is a lacking of Bass when using the CD player as my input. Any ideas what I should be looking for to solve the issue? it didn't do this before it was moved and don't know where to look : A bit of background, it's a Pioneer amplifier and US Audio speakers and subwoofer. A nice "middle of the road" system which i've been really happy with _2:
PROJECT - '77 XC Falcon 351C - Click Here DAILY - '05 Ford Territory BIKE - '12 Suzuki GS 500 |
20-06-2005, 10:50 AM | #2 | ||
Social Disaster
Sounds like a grounding issue, check all cables are in good condition and plugs and leads are all fully plugged-in. If you tend to stretch wires, this can damage them inside without any visible damamge.
Buzzing is almost always a symptom of bad grounding.
1995 EF Falcon GLi, Auto, 4.0L I6 Mods: 3.73 LSD | Darkest legal tint | tinted back lights | Sprayed Dash | Custom Trims Sound System: Fusion front splits, rear 3-ways, and 2 x 12" subs with ctrl, 3 x Fusion amps | Clarion HU | 1F Cap | 60GB Zen Xtra | 800W RMS output! |
20-06-2005, 11:04 AM | #3 | ||
Social Disaster
Also, I just thought....
If the cables going into the amps (input) aren't well shielded, make sure they aren't eccssively long and aren't coiled or run past and electrical gear (like fans, televisions, etc). The buzzing may also be caused by interference As a last resort, I'd say there is an internal grounding problem (like a dry solder joint come loose in the circuitry from you moving it around). That would be a warranty or repair shop issue.
20-06-2005, 11:05 AM | #4 | |||
Might try running a different wire to the sub than as well, see if it has an effect.
20-06-2005, 11:07 AM | #5 | |||
Social Disaster
Buzzing would come from a cable before the amp in the system ;)
20-06-2005, 11:12 AM | #6 | |||
20-06-2005, 02:37 PM | #7 | ||
GT4.
We have a Jenses SPX twin cone sub at our place which did the same thing. I emailed Jensen about the problem and they told me to make a modified adaptor using a double adaptor minus the earth pin.
Plug the adaptor into the wall, and plug the sub into it and it wont buzz no more. Dodgy i know. But bothe SantoItaliano and I have the same sub and have had to do the same thing. |
20-06-2005, 05:01 PM | #8 | |||
20-06-2005, 07:36 PM | #9 | ||
GT4.
Make yourself a Modified adaptor NOT the outlet.
1. Get yourself a Double adaptor (you know what that is, goes into one otlet, creates two more, Bingo!) 2. Unscrew the double adaptor and remove its earth pin (The bottom middle pin) 3. Plug the modified double adaptor into the power outlet, and then plub the sub into the double adaptor. You will not hear any more humming from the sub. Capeesh? Tell me if it works |
21-06-2005, 09:40 AM | #10 | |||
The buzz won't hurt the sub will it?
21-06-2005, 09:58 AM | #11 | ||
PM me if you want
That idea can work as long as your sub has a 3 prong plug otherwise you will be spending time on money for nothing if the sub only has a 2 prong plug
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
21-06-2005, 10:27 AM | #12 | |||
21-06-2005, 01:23 PM | #13 | ||
GT4.
Dont take the earth pin off the subs plug, take it off the double adaptor. If it doesnt work, its easy to put back on anyways.
21-06-2005, 01:33 PM | #14 | ||
PM me if you want
You would be surprised how literal some people take advice at times, best to check
Yes dont remove the earth prong, mod the adapater
21-06-2005, 07:04 PM | #15 | ||
BF F6, APV SR3900
hey danny..
the sub amp itself the other day.. dont know if it has anything to do with it.. go a google search for "ground loop problems" coz that what you have got...
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
22-06-2005, 09:38 AM | #16 | |||
I think I will try connencting just the Amp and Sub to the same power outlet, and having nothing else connected to power and see if the "BUZZ" still exists...
22-06-2005, 09:46 AM | #17 | ||
PM me if you want
Yeah I think you may be on to something there, my sub started to buzz a little in our old place but only after we had a power surge (which may or may not happened in the place you moved into), since moving to a new place (as in brand new) it has all been quiet and well behaved
22-06-2005, 10:40 PM | #18 | ||
BF F6, APV SR3900
mine happened after they installed foxtel digital..
apparently cable/sat tv has a big impact possibility...
05-07-2005, 07:03 PM | #19 | ||
Posts: n/a
ex-installer .Makesure u have good thick rca leads no longer than 3 meters and not near tv vcr mobie phones lights . If the cable is lo qty or near a tv some times makes buzzing noise.
06-07-2005, 11:28 AM | #20 | |||
btw the sub still buzzes with the adaptor with an earth pin removed! Any further ideas?
06-07-2005, 11:39 AM | #21 | ||
Social Disaster
Get a line conditioner. A small unit will be fine. We use them at work (I can get them cheap!) they have a backup battery to clean out any surges or brown-outs and they will clean out any ground osillations or looping problems.
Dunno how much these cost on the street... maybe $200?? If you get one plug in a powerboard and run your entire home steroe and PC off it. They usually have phone line filtering too.
06-07-2005, 11:43 AM | #22 | |||
06-07-2005, 01:15 PM | #23 | ||
Posts: n/a
I have'nt any more things to try bar a inline rac filter i haven't ever had to use one but they are good from what i have read and been told but not cheap. Final thought did u try and see if one of your mates has a system and try it out on theres and see what happens.
