#31 | |||
Smile
Ford could have easily wacked a nice blower on the xr6's as standard for performance .Instead they fitted newer cars with turbos which go nowhere when you floor them until they build up boost. Not exactly my cup of tea when it comes to a performance car. Perhaps I may go past a ford dealer and drive the new xr6t to convince myself they pack enough excitement for me to part with the money.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#32 | ||
Smile
Even the grandpa toyotas have superchargers
http://www.themotorreport.com.au/147...ing-the-bland/
#33 | ||
hehe my EA with 3inch straight thru system megaflow muffler, was 116db.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
#34 | ||
Irregular member
I looked into supercharging for a while also until I found out about all the legal issues and extra costs, which I have since forgotten. I just love the fact it's always running and makes that whiny sound with the revs and old Spitfire fighters in the Battle of Britain had them and all that.
![]() Is it possible that an aftermarket house can produce a supercharging "kit" with pre-certified compliance in agreement with the govt, that can only be fitted to cars with certain types of mods? Then they can go through a reduced inspection / testing period to be properly certified. I've been told mixed news about the fuel economy, but the way it works suggests it is negative in today's quite heavy traffic. Call me crazy but what about a clutch that is controlled by a cockpit switch that can engage and disengage the supercharging unit, as well as letting the air bypass its intake for normal "stock" pressures? That way general day to day driving can be uneffected. There was also this guy around my area with a green Commodore wagon that had one, with a BOV. The thing sounded like a truck and you could hear him coming from half a kilometre away on a quiet night. When he put the pedal down it was like a drag strip - the noise was just so illegal. Eventually he had it toned down and now I don't notice him, but before I always knew when he was coming by.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
#35 | ||
I'v only had mine fitted for a couple of weeks, but as far as fuel consumption goes I'd have to say it would seem to improve it when driving normally.
Prior to fitting the blower I had the diff gears changed from stock 3.08 to 3.89's but between the time these were fitted and the blower was, I didn't travel more then 100km's so am unable to judge how much the gears effected the fuel consumption. Since fitting the supercharger my economy seems to be more or less unchanged from prior to fitting the diff gears, on the first two tanks prior to having it checked on the dyno my average worked out per tank was between 12 and 13L's per 100km's with both tanks I wasn't giving it much stick. On the last tank economy was more then 16L/100km, but this included 14 wot dyno runs and a fair bit of flat footed driving. |
#36 | |||
Smile
One thing that totally confuses me is how a stock ford au ever passed emmissions when they were made. Every stock ford au I have seen on a dyno runs pig rich in the midrange.The carbon emmisions on a stock au must be high.
#37 | |||
Sly like a G6
Don't forget the official ADR tests are drive-cycles. The total emissions over the drive cycle are what counts, not transient emissions at any point. And the cat's job is to take care of a heap of those emissions... make sure yours is in good shape if you go this way.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
#38 | |||
Sly like a G6
#39 | ||
Smile
If I can get a big enough system I may go sc with lpg.I then should be able to crank up the boost as well.
#40 | ||
Smile
300 rwkws will be obtainable and I wont be paying alot to fuel the car.What more can a man want?
#41 | |||
Sly like a G6
Talk to some of the performance shops and any hot-rodders you meet about the engineers in Sydney. Some are more constructive than others... there are about 6 in Newy but I've had numerous references to 1 and only 1. His wife's daily drive is a 350/350'd Volvo 264...
#42 | |||
Smile
So the results of the test are for the total test ..correct?
#43 | |||
Smile
#44 | ||
VFII SS UTE
stav i not shure what type of blower would suit you ??
i had a vr ss with a littlefield pd, that was a nightmare on the street trying not to drill the car in front. but a vortek/sprinteck type is more gentle (for lack of better word's). so now the "forced" bug has bitten and how, so keep me informed on what you do
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
#45 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
#46 | |||
#47 | |||
Smile
#48 | |||
RIP...
![]() Seriously though, virtually any forced donk will perform outta this world if the boost is screwed up enough. It then simply becomes a challenge to hold the engine together, and that ain't rocket science either. Don't forget a forced 2L 4 pot can have similar overall characterisitics to a 6L V8 with enough boost. BTW, I reckon turbos are the go.
. Oval Everywhere... |
#49 | |||
Sly like a G6
![]() Yes the test measures total emissions over the drive cycle (the whole test). So there can be some trade-offs along the way, a lot of HC at WOT, a lot of NOx in lean cruise, can be offset by closed-loop emissions that are well under the limit. One thing to watch is that the RTA's test cell measures emissions from the whole car, not just the tailpipe. So a fuel or oil leak can send your HC sky-high. Check that your diff breather hose isn't broken between the diff and the body, a common problem on AU wagons. I've never traced mine but I'd guess the fumes go into the intake somewhere so they can be burnt and processed by the cat. Also if you have any engine oil leaks they'll need to be fixed and the engine steam-cleaned or similar.
#50 | ||
Sly like a G6
stav, am suffering bad form flu & fever. have lost interest in food & internet... not good 4 a lardy like me... jus wan 2 curl up & die atm... have some good stuff to post but is long post, not cohohererent enough atm to mpost, will get back 2u when feeling better...
