Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > FPV-Tickford Club of NSW > FPV-TCNSW Club Discussions
Old 01-06-2008, 04:17 PM   #1
soco3594
Default XH door locks
Hey guys. I am having alot of trouble with the door locks on my 96 xr6 ute. The passanger side door lock seems to be the problem because the handle is very stiff and I can't lock the ute at all. When i press te button on the key the locks go down then come straight back up. The same happens if I lock the drivers door using the key and I can't seem to get the passanger door to lock.
Has anyone had the same problem and if so what did u do to fix it? Is it simply a case of replacing the lock?
cheers
soco3594 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 07:18 PM   #2
bnotman
you will find that one of the door actuators is probably dodgey. disconnect one at a time and operate the lock. i would suggest you try the passenger side first as you feel this is the faulty one.
bnotman is offline   Reply With Quote Multi-Quote with this Post
