Has anyone had the drive line bolts can loss on their focus?
I just had my wifes car fix it had a tick around the drivers side wheel it turns out it was the drive line bolt coming loss. It was a 05 focus if you hear a tick get it checked.
scams |
4dlvr
my car makes a squeaking sound, every time i reverse, or do sharp turns, most of the time it will happen as im letting of the clutch... could this be due to the same problem
96 EF FAIRMONT Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust. 215rwkw @7psi |
#3 | |||
2007 Ford Focus Zetec
Last time I had a squeaking problem on a different car, it turned out to be the input shaft bearing. It happened mainly when taking off, and turning. |
